Question about Gateway Computers & Internet
My Gateway Model MT6711 was working and in the middle of my job shut off and will not start again....I had it plugged into wall socket. I get nothing....no lights at all ....what do you think the problem could be? thank you
  • Gateway Master
  • 3,051 Answers
It sounds like to me you have a power supply issue here check and see if there is any fans or noise from the powersupply when to try to boot if so unlpug the power cord from the powersupplu and press the powerbutton and hold it in for 15 seconds then release reconnect the powercord and try to reboot ok if nothing please keep me informed there is still a lot of advice i can give you best regards mike
Posted on Aug 23, 2008
Gateway c 140 xl won't boot
Try the following
  • Plug the unit directly into the wall, no adapters
  • Turn off the power at the wall socket
  • Hold down the power button on your device for 30 seconds
  • Turn all power back on and try boot again.
if that doesn't work I cant help any further, sorry.
Apr 17, 2014 | Gateway C-140 C-140S C-140X C-140XL M280
Gateway desktop
check at any other power socket or plug any other working equipment on the same wall socket to check if the power is ok in the wall socket
if all ok then either your power cord to the computer is not properly plugged in the computer or the computer power supply may not be working.
you may then require technical assistance of computer mechanic.
Aug 30, 2012 | Gateway Computers & Internet
My p-7901U FX made a popping sound, turned off completely (crashed) and now won't turn on. After unplugging everything from the laptop and wall sockets, I plugged the power adapter into the wall
It looks like you had a component burn out somewhere. Save dismantling it and checking for component failures try contacting the Gateway support site:-
http://support.gateway.com/s/Mobile/2009/PSeries/P-7801u/P-7801unv.shtml
Feb 08, 2012 | Gateway P-7801u NoteBook Intel Core 2 Duo...
Shutdown problems
I assume it is not shutting down. Do a complete reset, unplug computer from wall push power button in for 3-5 seconds, then plug it in and restart the machine. Then let it complete the boot up process then go to start and shut it down again see if it shuts down now. Thanks for the question hope this assists you. John
Jan 21, 2011 | Gateway DX482203 (PTGA002009) PC Desktop
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
Error 1200. i have tried to resolve using the steps in the manual. No luck The model is Lexmark 4720 Maltifunction printer
I managed to fix the problem. Error 1200
Checked for paper jam, no luck
Unplugged the USB connection and from the wall socket, no luck
Took the cartridge out and reloaded them again, no luck
Switched the whole computer off and then logged in back again, no luck.
Uninstalled the software.
Installed the software, driver, message "computer cannot communicate to the printer", but the scanner, fax and copy started working.
Deleted all pending jobs
Shut down the computer then logged in again.
Bingo, the printer started working.
Hope this helps
regards,
Tara
Sep 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
My gateway model is mt6711
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
8
Aug 31, 2008 | Gateway MX6030 Notebook
My computer won't work
most clicking sound are made by failing harddrive... check with gateway people again if it is still under warranty and ask them to replace the drive or fix it.
fyi -- if it is really the hard drive that is making the clicking noise... there is a big chance that you will loose your data
Jun 03, 2008 | Computers & Internet
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
