Question about Motorola Mobility i530 Cellular Phone
No signal my phone displays no signal all the time
Signal is does not indicated in nokia 6233
Go to phone settings click on the network,it will bring out list check the one that says network indicator then check on it, it will show off/on then click on. it will start to indicate if not that means the phone is bad.
Dec 15, 2011 | Nokia 6233 Cellular Phone
Tip
Nokia secret codes
On the main screen type
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
on Jul 15, 2010 | Cell Phones
Tip
Nokia Mobile Secret Codes
On the main screen type in: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This will clear the LCD display(operator logo). *#0000# To view software version. *#2820# Bluetooth device address. *#746025625# Sim clock allowed status. #pw+1234567890+1# Shows if sim have restrictions. *#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start) *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restart If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345 Press *#3925538# to delete the contents and code of wallet. Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \ *#7328748263373738# resets security code. Default security code is 12345 Change closed caller group (settings >security)
on May 19, 2010 | Nokia 1100
How to remove the master security code for nokia mobile model No:1209 plz tel me
*#3370# - Enhanced Full Rate Code (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
May 01, 2011 | Nokia 1209 Cell Phone
I whant learn all nokia 6300 hide code please
on the main screen type, *#06# for checking the IMEI (International Mobile Equipment Identity).
Jan 25, 2011 | Nokia 6300 Cellular Phone
Need programming codes for Nokia 7205
Is there a specific reason you need the code? The following are the most common nokia programming codes: On the main screen type in:
Hope this helps, Joe
Feb 19, 2010 | Nokia Intrigue 7205 Cell Phone
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even...
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even received messages. need your advise. pls. help.
Nov 06, 2009 | O2 Xda Zinc Cellular Phone
Cannot get a signal on my nokia 6021
You need a new phone, water and electronics are not a good thing.
Sep 21, 2017 | Nokia 6021 Cellular Phone
Can I receive and manage text messages on my parrot ck3200ls
Hi, no you cant receive and manage text from this handsfree, the signal strengh is displayed if the phone allows it, some phones will display battery and signal, some only battery etc.
Hope that helps
Oct 17, 2008 | Parrot Ck3200ls Lcd Color Display For...
No network coverage/signal problem
i had no display on my nokia 3230 cellular phone. now its ok but it has no network coverage/no signal . plz help me..... .
Sep 24, 2008 | Nokia 3230 Cellular Phone
Motorola Mobility i530 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
