Asko D1996SS Built-in Dishwasher Logo
Posted on Jun 29, 2011
It's actually model number D1996. Problem is that
5 Related Answers
Anonymous
  • 641 Answers
  • Posted on Aug 27, 2007
SOURCE: Detergent Door not Opening
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, you should replace the wax motor that operate the cup door. Good luck
Anonymous
  • 640 Answers
  • Posted on Nov 20, 2007
SOURCE: detergent dispenser
I belive your problem is the top wash arm.Make sure all your screens are clear in the tank.check the wash arm holes for obstructions and make sure there not cracked.let me know how you make out.
Anonymous
  • 351 Answers
  • Posted on Mar 02, 2008
SOURCE: Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Aug 25, 2008
SOURCE: Dishes are ALWAYS WET!!!
It is 1 of 2 things here,your either not using rinse aid or your heater is not on.Make sure you have selected the option "heat dry".
Please Rate This !
Anonymous
  • 171 Answers
  • Posted on Oct 13, 2008
SOURCE: GE Dishwasher
Hi tucker19,
I'm Harvey the Master Plumber.
Your question is: You just purchased a GE Dishwasher from Home Depot...Its a QuietPower3...and after you run it, there is detergent build up on the detergent dispenser lid and residue on dishes...HEAVY RESIDUE...Why????
Are you useing a dry soap? If so, try a liquid. Make sure it says DISHWASHER soap on it. Also, use half as much liquid as the dry. Some new d/w's can be tempermental that way. If it persists then use the warranty.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 • Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
Bosch washer reverts to rinse and hold. Detergent dispenser doesn't open. Whatever other cycle is pressed (after much pressing) the machine goes into rinse mode.
Hello, welcome to FixYa.
If you can provide the model number (usually on inside of door frame or tub frame around door opening as shown here for bosch)
...I'll see what I can find for you.
There are many possible scenarios so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
The compartment where the dishwasher tablet goes in doesn't always close.
It might be helpful to know the model number of the dishwasher.
It is likely the detergent dispenser compartment lid has a faulty latch. This gets fixed by replacing the whole dispenser.
2answers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
Won't dispense dishwashing detergent
There is a recall on these that has to do with the rinse dispenser and fires. Go to the manufacturer's site with model and serial number to see if yours is recalled. Rinse agent drips on the wiring inside the door and can cause a fire.
4helpful
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
The cover of detergent dispenser does not open..
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
