Question about Olympus Camedia E-20N Digital Camera
Sync switching voltage
Should I be concerned about sync switching voltage from my studio strobes or flash units
    Master:
  • 852 Answers
No, the E-10/20N has a built in filter that protects the camera from high switching voltage.
Posted on Aug 31, 2005
Shooting in a studio with flash, frame 1 is exposed perfectly. Frames 2-12 severly underexposed if any image at all. This has now happened twice.
How fast are you popping off shots? Be sure you're allowing time for your strobes to recharge after each photo. Also, depending on your lense, there is a switch for X and M sync, X is for electronic flash, M for old flash bulbs - if you've managed to slip it off of X to M you'll get no use of the strobes. It's also possible that your sync cord has came unplugged or loose from the PC socket or the strobe/power pack itself, or that the cord is simply bad (it happens frequently) - try a new cord. But, be sure you're allowing 2-3 seconds at minimum for your strobes to recharge unless you're somewhere you're sure they're setup and able to cycle faster.
There is nothing electronic in this model to go wrong, including the lense, so whatever is wrong is either in a user setting, or in equipment from the cord on.
Jul 14, 2011 | Hasselblad 501CM Medium Format Camera
I purchasing this flash from b & h and want to know if it will sync with my studio lights slave function so both flashes will be fired at the same time? I figure I'll have to use the camera in manual...
Presuming you bought a shoe-mount flash for your Sony A900 and set the camera and flash to manual so there's no pre-flash to prematurely trigger your strobes, and presuming your studio lights have built-in optical slaves, you should be all set.
Henry Posner
B&H Photo-Video
Oct 10, 2010 | Cameras
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
Syncing Nikon D300 with 600VR strobe system
A wireless system such as the line of Pocket Wizards is a good choice- the are builr to professional standards and are very reliable.
If you wish to hard wire your flash unit to your digital camera, you can purchase a protector wivh reduces the trigger voltage to a safe level refatdless of the age or design of the flasg system you are goinf to use, Under no circumstances should you use this combunation of equipment without a radio triggering device or the protector, The protector attache to the hot shoe of the camera and provides a standard PC synch cord terminal for connecting your flash system to the camera.
You can test the voltage by putting a volt meter set a 250 or 500 VDC across the synch socket in the flasg unit, If the meter deflects negatively just revers the polaity for a correct reading. If there is under 5 volts there is ptobably no issue, however, I still would take no chasces abd use a radio or a protector. If the falsh won't fire with the radio or protector in place, tha probably means tha the synch voltage is very low.
Nov 22, 2008 | Novatron 1000ws Standard Head with 25'...
Does the DiMAGE A1 support any external flash including studio light?
Yes, it does. It is usable with any external flash using sync cord to sync terminal. (sync voltage: below 400V, correspond to antipolarity)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
3000Z and Speedotron Flash power pack
You also may have a faulty hot shoe adapter or pc cord. Check them with an ohm meter, or with an old 35 mm camera. Or just short out the hot shoe contacts with a piece of metal and see if the strobes flash.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Studio Strobe not firing with Coolpix
The Coolpix line of cameras require a "tip positive" sync connection to an external strobe unit (when using the Nikon AS-15 Flash Sync Adapter). On some external Studio Strobe units the sync polarity is easy to change because of the type of plug: On this type of connector simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user. If the Coolpix does not fire an external strobe check with the strobe manufacturer for sync polarity info.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia E-20N Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
