Question about Fujitsu AMILO D-7820 Notebook
Philips 30pf9975 hi im currently having problems getting a picture on my flat tv from my laptop
  • Illimar Saatvali
    Illimar Saatvali May 11, 2010
    What video adapter you use: ATI, Nvidia, Intel... ?
  • Illimar Saatvali
    what connection you are using for tv RCA, VGA or S-video?
I need help on getting a picture on my tv & I have sound
The inverter board needs replacement. You can get the inverter board at the following link www.tvrepairworld.com
Jan 10, 2013 | Sylvania 6632LG 32 in. LCD HDTV
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Connected to pay TV.Picture goes off but sound remains.Switch TV off and after 20 seconds most times picture returns.TV is Phillips Cineos 6 yrs old
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Take care in solving the problem....
May 10, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Tv will not stay on and red light blinks
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one area of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem , im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Panasonic TCP50G25 50 in. TV
The red light keeps flashing
Nov 03, 2010 | Samsung LN40A450 LCD TV
My tv suddenly stopped working it is flashing 2 lights, one green and one red
Nov 03, 2010 | Televison & Video
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
30 inch philips tv 30pf9975 /17. Gets sound but only blue screen through component hookups. Sometimes works all day but intermittenely gets blue screen.
dear i think there is a fault in your moniter cable means the two cables red and green is broke down or damage inside the plastic cotted wire.sometime when u move the wire the broken ends of the cable meets and u get clear result but when they disconnect u get blue screen
Nov 05, 2009 | Philips 30PF9975/17 Monitor
Fujitsu AMILO D-7820 Notebook Logo
111 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
