Question about GE Refrigerators
My fridge side is freezing everything and l do mean everything. We have the fridge side turned to 1 and the freezer side to 3 and every liquid freezes solid milk, juice,sour cream you get the picture. HELP
  • ddrutows Aug 23, 2008
    where is it ? can l replace it ?
    Scholar:
  • 163 Answers
    Master:
  • 521 Answers
It’s the problem of ventilations sir.because the cold air which collects in the fridge comes out through ventilations .and if the ventilations are blocked.the fridge will become extra cool and freeze all your food items.just clean the ventilations carefully. .the ventilations are located below each tray on the side area.defrost the fridge for 24hours.and off all the temperature settings.when you ON the unit after 24 hours set the temperature back as per your requirements.and it will work properly as normal.please do rate the solution.thanks.keep me updated.
Posted on Aug 23, 2008
  • 876 Answers
Check the temperature in the freezer section. If it is less than 10 degrees F., turn the thermostat to warmer. If the temperature in the freezer is 10 degrees F., leave it and go to the temperature control in therefrigerator. It is a damper that controls cold air from the freezer. Close the damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If this does not solve your problem, then your thermostat is kaput and you need a service call.
I hope this helps. Thank you for using Fix YA!
  • 435 Answers
Hi ddrutows,
Try these measures to solve your problems.
The "minimum" temperature setting is usually the coldest setting and it certainly could be below 32F in the fridge and things will freeze.
If the temperature adjuster is a dial type then there should be a "normal" set point with "colder" and "warmer" notations on either side of it. If the dial is below the "normal" point then turn it up to at least "normal". If the dial is at "normal" then move it a little toward the "warmer" setting and let it sit for a day and see if things appear to thaw a bit.
If your fridge has a digital temperature indication then the "default" is usually about 38F. If it is set below that then bring it up to 38F. If it is already at 38F or higher then increase it by a degree or two. Let it sit for a day and see if things thaw any.
The normal temperature in the refrigerator section should be about 38-40F.
    Genius:
  • 1,665 Answers
The compressor runs whenever the refrigerator thermostat calls for cooling (and the defrost timer is not in a defrost cycle, for self-defrosting units).
So your thermostat is faulty or disconnected and does not control compressor's operation.
    Master:
  • 623 Answers
Check back wall freezer temperature
If your refrigerator has a motorized damper in the fridg, disconnect plug to it and jam open the damper door half way
motorized damper is behind a cover on the freezer side of the refrigerator.
Just stick a thermometer in the freezer.
  • 1,879 Answers
Means only one thing, the thermostat control is broken.Have it replaced.
  • GE Master
  • 19,396 Answers
Start lowering down temperature, you may need to defrost fridge overnight.
  • 2 more comments
  • Ginko
    Ginko Aug 23, 2008
    Check also following suggestion from Repairclinic:
    The food in the refrigerator freezesThis
    is a common problem that often doesn't have a clear, permanent
    solution. The first thing to check is the overall internal refrigerator
    temperature (see the Appliance Accessories section for a
    refrigerator/freezer thermometer). The proper temperature should be
    between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If
    you find that the temperature varies a lot from the top shelf to the
    bottom (where it is coldest), try putting produce and other sensitive
    products on a higher shelf.
  • If the temperature is too
    low and you can't make it warmer by adjusting the thermostat, you
    probably have a defective thermostat. If so, you need to replace it,
    because they cannot be repaired. Other possible problems are a leak in
    the sealed (refrigerant) system, cold air migration (in side-by-side
    models) or a defective air damper. These problems can be quite
    difficult to locate and correct, we recommend you contact a qualified
    appliance repair technician.
  • Ginko
    Ginko Aug 23, 2008
    Do first a complete defrost, this often solve the problem, as will stop ice from accumulating. If it does not work it is usually a defective thermostat. You can buy parts by inputting model number here, or use the phone number printed on owner manual to call in repair.
    Do defrost first.
  • Ginko
    Ginko Aug 23, 2008
    Particularly if it is freezing on one side the thermostat can be jammed, often you fix it by defrost, if it keeps freezing then you have to work with temperature, or in the worst case to replace thermostat.
  • Ginko
    Ginko Aug 23, 2008
    How does a side by side domestic fridge work
    Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
    Jan 23, 2016 | Refrigerators
    Fridge Freezes Everything
    there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
    Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
    The freezer has been melting ice-cream
    The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
    May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
    My freezer side isn't freezing. fridge side seems to be working
    If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
    Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
    My fridge side out the blue is freezing. All
    I had the same problem with mine a few years ago. After two thermostat replacements and still having the problem, the third technician out explained that if you blocked the vent on the inside of the refrigerator, (the shelf below meat drawer,left side) it could cause freeze up. Sure enough, haven't had a problem since.
    Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
    Fridge freezer HNMF2805-80. fridge is freezing
    isnt that the highest you could put it. how about taking it down to 1 or 2. it should say on the nob.
    Jan 28, 2010 | Hoover Refrigerators
    Liquids frozen in refrigerator, no water from water dispenser
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
    The problem could be the electronic control if you have one or the mechanical linkages.
    Sep 22, 2009 | Kenmore 53642 / 53644 Side by Side...
    GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
    The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
    Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
    Refrigerators Logo
    629 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
