Question about Motorola MU21CV (1 Channel) 2-Way Radio
Motorola GM300 Question
Hello - I have GM300 and about 2 seconds after I turn it on it starts to squelch and the transmit light is on... radio transmits over it but I don't know how to get it to stop?? Any ideas? Thanks
  • Jason Aug 24, 2008
    Thanks eradiostore...I know it still does it with the mic off but I'll check he antenna connection in the morning
I HAVE GM300 AT MY SIGHT AND THE OUT PUT IS VERY WEEK THE SPEAKER IN THE UNIT IS OK THE SIGNALES ARE VERY WEEK PLEAS SUGGEST THE SOLUTION ON MY E MAIL JNV.CORPORATION@GMAIL.COM OR JNV.CORPORATION@HOTMAIL.COM SUDESH
Posted on Sep 18, 2008
    New Friend:
  • 109 Answers
Make sure that the accessory pins on the back of the radio are not shorted to each other. To learn more about the accessory pins on the GM300 go to www.batlabs.com .
Pat N5SLI
Posted on Sep 05, 2008
  • Motorola Master
  • 1,654 Answers
Check your antenna connections and coax for loose connections or damage. Also check your hand mic. See if the problem disappears if you turn on the radio without the mic attached. The two most common problems with a mobile radio are antenna and mic problems.
If you feel these are in order, it would be wise to have a tech look at the radio.
Posted on Aug 24, 2008
Tx motorola gm300
You have transmit and voice out good..Finals are good and preamps on 27 mhz. Recieve could be speaker. Change External speaker with a Radio Shack plug in External 4 inch speaker with male jack. Turn volume up halfway. Turn off squelch counterclockwise to hissing noise. Turn off Noiseblank NB switch to off. Turn off Dynasquelch switch(options on new models) Turn Off ANL to off or on back and forth till truckers or friend is heard the loudest. If still cannot hear could be capacitor, transistor or the worst thing ever 32 pin IC chips(OH NO! throw in garbage unless you have a Cb repair shop-Radio Shack repairs their own(REALISTIC BRANDS RADIO SHACK. INC) LET CB SHOP HAVE A LOOK SEE OR A REPAIR MAN OF ELECTRONICS RADIO OR TV GUY. SOME JUST WORK TV'S BUT RADIO IS WHAT YOU NEED.16 or 32 PIN IC'S ARE VERY MICRO AND WON'T HANDLE HEAT OR STATIC CHARGE OF CARPET
-walking on carpet and zap with finger like a wizard. Bip its gone $100 chip shot to pieces-or atleast it will cost that when you order from Tokyo Japan with Shipping charges-Agonizing!
Jul 12, 2013 | Radio Communications
How to change the squelch on mtx8000
You can always have a radio receive. To transmit require an FCC License, and you need authorization to "Talk" to Public Safety. There are large fines and possible jail time to talk on channels you are not authorized for, especially Public Safety. Sadly, your radio is programmed to monitor only when the button is held down. The frequencies in your area working are a lucky coincidence. Take it to an Authorized Motorola Dealer and pay to have it reprogrammed. Radio is not field programmable. Hold onto your wallet, they are expensive to have programmed. You should have bought a high end digital scanner.
Aug 29, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
Can you give me the specs on: Motorola radius GM300 radio? Model: M43gmc29c2aa wanting to know how many channels and how many watts. Thank you.
I think this is what you are looking for: Motorola Radius GM300 VHF 146-174mhz 16 channel 45 watt mobile (MDL# M43GMC29C2AA)
Jul 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Does a motorola gm300 model number m43gmc29c2aa have ctcss or PL TONES capability's?
Yes, it seems to me that the GM300 radios did have tones as programming options. They were programmed by the dealer using radio service software (RSS) when the frequencies and other channel information were entered. Of course, Motorola discontinued the GM300 a long time ago, and they were wide-band radios, so you could not legally transmit with them anymore. However, you could find someone on eBay to program them receive-only with or without CTCSS (PL) tones and then you could simply listen to them.
Jun 24, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola gm300
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Motorola EM1000R Two Way Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Motorola MU21CV (1 Channel) 2-Way Radio Logo
428 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
