Question about Dell Photo 964 All-In-One InkJet Printer
Bought it a month ago printer status says ready but jump to file willnot print
Will not not print go to save file but staus says ready
You need to ensure your document isn't set to print to a windows document printer. Change it to your defaut printer and it'll work.
rstrg2
Posted on Sep 04, 2008
Canon iR4570 printer problem
I suggest that you reinstall the driver of your printer or update it to the latest version. You can use RadarSync to autodetect the driver update.
David
May 13, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
My printer will not communicate to my printer, and it did recntly. just stopped working a month ago.
Do a normal power off (leave the printer powered on) on the computer and after 5 seconds re-power the computer on and you should hear the printer do a reset and become ready. I've had the same problem, it's in the printer.
Jul 22, 2011 | Lexmark X5650 All-in-One InkJet Printer
How to take status page in canon lbp 3300
There is 2 ways. Print a copy. Staus windows popups.Then clik options , utility , configuartion page. take print.Another way. Go to preferances,Bottom a printer icon with exclaimatery mark clilk it ,open status window, then follow the previous steps.Cool
Nov 11, 2010 | Canon LASER SHOT LBP 3300 Printer
Printer is not working. There is no error light on and the ready symbol light is on. Nothing willnot print
Have you checked if there are any Documents Stuck in Queue to print ? ( under Control panel - Printer and faxes folder )
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone. ( Refresh the Printers and Faxes folder )
If this does not fix the issue :
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 03, 2010 | HP LaserJet P2015dn Printer
95-I OWNE A 5500-6600 ALLL IN ONE PRINTER. WHEN I SELECT PRINT I GET A SCREEN TO SAVE THE FILE. IT STILL WILLNOT PRINT THE FILE. JAMES PEWITT
James,
Re-try the print option. When the driver window opens, read through the options. Look for a box that says, "Print to file". If the box is checked, uncheck the pox.
Don
Jan 22, 2010 | Office Equipment & Supplies
Purchased a Canon i950 for years ago... printing beautifully... did not use for the last two months and now has just stopped printing... reinstalled driver, still same problem - does not print a test page...
Check if the printer status is ready under Control Panel- Printers.
Make sure that correct port is used (Printer properties- Ports tab).
Also, check if the printer is online. Control Panel-Right click printer and choose Use Printer Online.
Hope this helps.
Jul 30, 2009 | Canon i950 InkJet Photo Printer
Printer Problems...red status light glowing
Chances are that you have the same problem as found here. I am guessing that the toner waste container needs to be emptied (you can do it your self) and/or the sensor is acting up.
http://www.fixyourownprinter.com/forums/laser/34677
May 25, 2009 | Samsung CLP 300 Laser Printer
Printer
Check cable is secure from pc to printer
Check printer can print a status page via printer keypad and is online/ready
If these are ok then it is a print driver issue
Turn off printer, Unplug usb, delete and reinstall print driver
Jan 11, 2008 | Kyocera FS-C5030N Led Printer
Dell Photo 964 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
