Question about HP LaserJet 1600 Printer
Hp laserjet printer 1600
Can I se with just a black replacement cartridge
  • Anonymous Jan 29, 2009
    I don't know how to put the new black laser cartridge in. It has a pink piece of plastic on one end and something that looks like see through tape. Do I pull on it? I don't remember the last one having this.
  • mrvander Apr 18, 2009
    Can I put the cyan in the black's place and just get blue documents?
Replace supplies
Posted on Dec 19, 2008
  • sunil bharti Nov 19, 2008
How to replace hp 1600 drum unit from the cadgtrage
The HP 1600 uses an all-in-one toner cartridge and drum unit.
When you replace the toner, you replace the drum. The unit is NOT repairable or servicable.. you don't want to open the toner cartridge, you will only make a huge mess.
Mar 17, 2014 | HP LaserJet 1600 Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I have a hp laserjet 1600. We replaces all the cartridges and now I am getting shadow printing on the page please help what am I to do?
Did you replace cartridges with OEM HP cartridges or remanufactured/ no name cartridges? The failure rate for remanufactured color cartridges is terrible and it is likely that you have a bad cartridge.
Apr 26, 2011 | HP LaserJet 1600 Printer
The red and yellow cartridges print very pale from the left and gradually get darker. The black and blue seem OK...!!
you have dryed up ink in yellow side of cartridge cloged up from inside replace cartridges or try wiping it with alcohol...
Feb 17, 2011 | HP LaserJet 1600 Printer
My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
Feb 03, 2010 | HP LaserJet 1600 Printer
HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
Feb 02, 2010 | HP Office Equipment & Supplies
Hp laserjet 1600, can I just print in black and white if all the cartridges need replacing but I just replaced the black
Cartridge Out Override can only be enabled from the printer's control panel menu.
1. From the main menu, press (Right arrow) to System setup and press (Select).
2. Press (Right arrow) to Print quality and press (Select).
3. Press (Right arrow) to Replace Supplies and press (Select).
4. Press (Right arrow) to Override out and press (Select).
5. Press (Select).
I suggest setting your printer to print "black only" in the printer properties window.
Apr 20, 2009 | HP Office Equipment & Supplies
Hp 1600 laserjet locking up
It could be the release gear on the bottom right side(as your facing the printer) You can try removing the right cover and re seating it.
Jun 26, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1600 Printer Logo
297 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
