Question about HP Office Equipment & Supplies
Hp c4208 all in one printer not operaring due to "carraige jam" - HOw to cure???
  • 217 Answers
SOURCE: Printer carraige of hp photosmart 475 has jammed at the far end
unplug the device and try to move the carriage with your hand ,but do not force to move it .if it does not moves just again plug in the wire and on the printer.and the carriage will move when the carriage comes out.just check out the cartridges that r they properly installed.
Posted on Nov 29, 2008
SOURCE: Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Posted on Feb 15, 2009
  • 53 Answers
SOURCE: We have an HP C6180. Carraige jam with grinding noise
perform the steps in the webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=1153494
Posted on Oct 03, 2009
SOURCE: HP 5610 how to clear a carraige jam
Hi! I will be glad to assist you. here is the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&cc=us&lc=en&dlc=en&product=441125
this will solve your issue.
Posted on Oct 05, 2009
  • 1218 Answers
SOURCE: carraige jam. Screen says to clear carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • * Turn off the printer and open it to see where the paper is stuck.
  • * Manually move the carriage toward the opposite side.
  • * Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • * Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 28, 2010
Do you know a cure for the hp cp2025n panel message
The printer is probably due for maintenance.
Nov 30, 2011 | HP Laserjet Cp2025n Printer
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
Apr 10, 2010 | HP Photosmart C5280 Printer
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I get a carraige jam. It asks me to remove paper,
Sounds like it needs serious servicing. You can look at having it fixed but it may just as well be worth it to replace the machine.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Help hp psc 1610 all in one printer carraige jam
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Nov 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Carraige jam
If you can move the cartridge carrier, move it all the way to the left, turn the printer off and then on again.
Your printer may not be parking the cartridge completely so check the area that the cartridge rests over when parked for a sponge or wiper that is out of place.
I've pulled broken light bulbs, paper clips among the many things that can cause the cartridge from parking in the rest stop.
Regards,
Worldvet
Jul 09, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Cartridge carraige jamming
plz send it for repair as it is due to hardware failure
May 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
291 people viewed this question
Ben Johnson
