Hello
Sylvania is not listed with this Sony remote control setup codes. But you can find your device code by the following procedure.
Note
If no operations are performed for 10 seconds while setting, the setting will be canceled, and must be restarted.
1 Power on the device with its power switch.
2 Aim the RM-VLZ620 at the device you want to set.
3 Press and hold SET for more than 3 seconds.
* While keeping SET held down, press the desired Device Select button, then release both buttons.
* The selected Device Select button lights up.
4 Enter 9- 2 - 2.
* The SET indicator flashes three times to indicate that the setting mode has been entered.
* 3 flashes
5 Press and hold => to start searching
6 When the device turns off, release the button.
If you overshoot the required code, you can search for the next or previous code using the =>or <= button.
7 Press (+).
* The SET indicator flashes three times, and the indicators turn off
* To cancel the process
Press SET anytime
Notes
? If all codes have been cycled through once, the SET indicator and selected Device Select button flash once and turn off.
? If the setting is incomplete, the SET indicator flashes once and the indicators turn off.
? If you still cannot operate the device, even after setting the manufacturer's code using the Search function, another code may be available. Repeat the above steps to search for another code that works for most functions of your device.
