Lg 37" lcd 1080p a six months old after being on for 10mins flickers (bit of a fizzle noise) screen goes of but the sound stays on. Switch off and on again it does the same immediatly,Switch off leave for 10 mins switch on again it takes 10 mins to flicker and goes off. then it can be fine for a week be for repeating.this happns running just with an hdmi signal from a computer -or a signal from an arial -any ideas
  • 435 Answers
Hi banzi,
Try these check outs and solutions which could give you some assistance.....
1)
Ensure all your connections are properly pushed into the back of the TV, maybe you haven't pushed them in fully, also check the S-connector is properly tightened onto the sky box.
2)Digital TV signals are streamed at relatively low rates. They are, before transmission from the digibox to your actual TV, subject to error detection and correction.
Any errors will slow the TV reception down quite dramatically.
3)It is likely that your LCD TV has exposed a problem with your Sky setup. Whether that is to do with poor wiring, or an incorrectly adjusted Head Amp, is open to consideration.
4)I think you need to find the purchase reciept for your TV set....
You need to contact the manufacturer and explain what you have seen.
Then they should have a list of authorized servicers in your area, you need to pick one of them to replace a board on your TV set....
I think the DIGITAL board or one of the tuners isn't right, and I DOUBT THE TUNER, since you can only get HD into a TV set with HDMI or Component cabling.....
You gotta do it before your warranty expires......you have it right?
or
You need a professional TV Engineer.
I hope you liked my assistance and will consider it to be FIXYA!
Posted on Aug 23, 2008
  • Narmada Anand
    Narmada Anand Aug 23, 2008
    I chose these points from all over the web.........I found some solutions from web and some from my own experience.........
    Thanks.
    Master:
  • 521 Answers
Check if something loose conection.and reply.
  • tech expert12 Aug 23, 2008
    the link has the problem like yours to other customers which are solved by them.you can read there answers and solve your problems too.as if all the connections are properly connected then its the problem of front panel board .if the front panel is faulty this happns only while running just with an hdmi signal from a computer -or a signal from an arial .please do rate the solution .thanks.keep me updated.please check full page of the link provided as the solutions are provided at the end of the page.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
47LG70 - PICTURE WENT OUT. STILL HAVE SOUND. HEARD A POPPING NOISE WHEN PICTURE WENT. TV IS ONLY 1 1/2 YEARS OLD. ANY IDEAS WHAT MAY OF HAPPENED.
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
37 inch flat screen LG TV flickers
Take the TV to a local TV Repair shop.
Ask them to check the Inverter and the Power Supply.
Deffinately fixable.
Sep 06, 2009 | LG 42LC2D 42 in. LCD HDTV
Object was thrown at 37 inch LG 1080p LCD
The short answer, buy a new one.
A new screen will cost you about the same as a new tv, if not sightly more considering your brand and model of TV. There really is no reasonable price to replace the screen and is usually not completely covered by warranty(some manufacturers don't even include a broken screen as part of the warranty).
The price of your HDTV is not that bad. You could probably find the tv cheaper than the repair if you shopped around a little.
P.S. I'd also stay away from the busted TV itself (health issues).
Jul 26, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
I have a 37 inch 1080p lg tv which i have just connected to a ht503ph via the hdmi cable. when i am watching the dvd it starts to flicker then the screen goes all white an fuzzy (like the tuning on an old...
Hi elcrozier.Try changing the resolution from 1080p to 1080i in the system setting on the ht503ph. I had the same problem and that fixed it. good luck
Dec 21, 2008 | Audio Players & Recorders
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
