Question about Garmin GPS
My Garwin Nuvi 350 has no sound. Driving along the natigation voice stopped in mid-sentence and now we have no sound at all.
  • vanjenn Aug 23, 2008
    That's navigation (corrected spelling). It was set on voice for Jill - No sounds now whatsoever, no tone or voices. Everything else seems to work fine... Just no sound.
    Unit is not muted.
  • vanjenn Aug 24, 2008
    Already updated and installed the software before posting the problem. So your advice was insufficient and not helpful.
  • Garmin Master
  • 6,487 Answers
Make sure the volume is set to high , the little speaker icon on the right side of the main screen. If still doesn't work looks like the unit might be defective, and if its still under warranty have it replace..
Posted on Aug 24, 2008
  • 435 Answers
Hello vanjenn,
You have a great gps device.......
The problem that you told could happen if your device mute is on or there must be some problem with your software/firmware.Therefore, try these solutions to solve your problem:
1) Turn off mute.
With the GPS at the main screen, click the power button once. Then, click the "unmute" button at the bottom of the screen.
2)
Try plugging your device into your computer via USB, and update/reinstall the software on the GPS using "Garmin Webupdater".For this go to:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
I've fixed many probelms with my Nuvi 350 by updating the software, and maybe it's an issue that's fixed by a newer version of the software.
If both solutions doesn't work then the best way is to get it repaired by an expert/tech in this field or go to your nearest Garmin service center.
Thanks Vanjenn
Posted on Aug 23, 2008
  • 928 Answers
Try first turning it off and then on again.
Try to update the firmware. Go to the link below then go to unit software. Make sure that you have the device with USB cable attached to the computer.
http://www8.garmin.com/support/download.jsp
Its possible that it may be a problem with the software of the unit.
If that still does not work its possible that its a hardware problem alraedy
Garmin nui 350 Tried everything. My brother-in-law past away recently and dont no his pin # . is it possiable to reset and use garwin ?
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Aug 21, 2011 | Garmin nuvi 350 GPS Receiver
The voice on my garwin nuvi 1300 gps stopped working and it is not mutted
Either the voice file is corrupted or not selected.
1. To select a new voice:
  • Press TOOLS (Bottom right corner of the screen with WHERE TO and VIEW MAP)
  • Press SETTINGS
  • Press LANGUAGE
On this screen there are 3 items including VOICE. Press VOICE and select ENGLISH if it's not already selected. If that doesn't solve the problem the English voice file is probably corrupted and needs to be downloaded again.
2. To replace the corrupted voice file:
  • Download and install, to your computer, the latest version of WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • Connect your satnav to your computer and run the webupdater program.
  • It will find any updates to the satnav operating system. Select all and install them.
  • When the updates are installed webupdater will find optional updates including voice files. Select some of the English voice files and download them.
When they are downloaded safely disconnect your satnav and re-start it. You will then need to select one of the voices you downloaded as described in paragraph 1 above. This should solve your problem.
Aug 04, 2011 | Garmin nuvi 1300 Car GPS Receiver
Light/white screen display
Most likely a bad LCD display. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jul 24, 2010 | Garmin Nuvi 350 Car GPS Receiver
My Nuvi255W will be giving verbal directions fine, and then it stops in mid-sentence. After I enter a new address, it will stop in mid-sentence again.
I recommend you backup your favorites. Then I suggest a hard reset. This will clear up some erratic behavior. Finally, replace the firmware and system software using webupdate.
Replacing the firmware should allow it to run reliably like new
I hope that helps.
Mar 13, 2010 | Garmin nuvi 205W GPS Receiver
The voice stopped working on my Garmin Nuvi 350 in mid sentence
what has happened? my etrex said low batteries. I changed batteries. now all I get is searching for sattellites? can anyone help?
Mar 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350 gps receiver
Yes, the music should pause, the directions should be given and then the music should pick right up from where it was paused.
Dec 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
No sound
okay first i need to know the make and model many gps systems and almost all models are wired differnt
Dec 15, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
