Question about Lowrance LMS-330C GPS Receiver
GPS module not responding
I did the obvious checkin of all the connections. Nothing. I bought a new antenna for $200, hooked it up and it worked. The weekend came around, I turned it on and "GPS module not responding" again. What could it be?
  • Pirates96 Oct 04, 2008
    I have the same problem and mine is blowing fuses. The GPS is powered seperate from the sounder. I am still looking the solution to the blown fuses.
  • scott925 Mar 08, 2009
    This is the second time it's happend to me and I checked the connections and made sure the seperate power lead was getting power to the main unit. (whiched fixed the problem last time) but I have not tried getting a new antennea yet.
    I will let you know...
Check the power connections to the antenna
Posted on Sep 06, 2008
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
I have a lcx16 sounder gps with a lgc12s antenna receiver. The gps module is not responding Do I need a new antenna ?
more than likely you do or you have a bad connection. It's always best to take this sort of issue to a shop in the event something is wrong with the unit itself before buying the new gps.
Jan 19, 2010 | Lowrance LGC-12S GPS Receiver GPS Receiver
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Gps will not turn on lcx 27c
i have lcx 27c gps will not work locked up module not responding but has power to it
Jan 06, 2009 | Lowrance LCX-27C GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
X15mt
I believe the antenna on that model is a "smart" antenna, which means that the receiver is in the antenna, not in the display, and it is connected to the back of the display with a multi pin plug that provides power and data link to the antenna.
If the antenn is mounted directly in the path of a RADAR beam from a RADAR antenna on your boat, the antenna will not acquire satellites while the RADAR is on.
More likely you have a bad connection:
1) remove the display from its mount
2)gently tug on the GPS cable to see if it comes off without twisting. If it comes off make sure it is aligned, push it back on twist the locking ring and try again.
3) if GPS plug is properly installed and unit doesn't work, remove the plug and and check the pin holes for corrosion, also check the socket in the back of the display for damaged or missing pins. Anything that interrupts power or data will cause the antenna to stop working. If there are no obvious signs of corrosion or damage, then the problem is most likely in the antenna processor. If you have access to another antenna, or if you know somebody who has any model Lowrance with the same plug on their GPS try running your display on their antenna. If it works elsewhere then you need a new antenna, which is probably just as cheap to buy new as to have repaired. If it doesn't work then you probably need to remove the display and antenna and send it out for service.
4) Before you send it out there is a slight possibilty that the problem lies in your display processor. Make sure you have the latest software update in your display. The software version should appear on the display when you first start it up. Click here to compare your version to the most current version available. If your software is not current, download it to a blank data card, place the data card in your chart slot, and turn on the display. The screen will prompt you on what to do next. If that doesn't work then repair or replacement is your only option.
I hope this helps, please contact me if you have any questions , or if you decide to replace it I'll be happy to offer advice about new models.
Feb 10, 2008 | Lowrance LC X-15MT Sonar
Lowrance LMS-330C GPS Receiver Logo
870 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
