Question about Audiovox Xpress Satellite Radio Receiver with Vehicle Kit
FM output We have picked up our second XPress in a week, thinking the first one was defective, but it's something goofy. The FM signal output seems very weak. If you put your finger on the back of the XPress unit (the lower right side, where the serial sticker is), the output is great. Move your finger off it, and there's nothing. We've tried all the FM open frequencies in our area, but this happens on every one of them. Did we miss something in setup? Or did we get two defective Xpresses in a row. There is, BTW, a three-bar indicator on the satellite signal. And it's clear.
  • Chad Burke Aug 26, 2008
    I am having the same problem with my Xpress. I have now purchased my second Xpress and it worked great for a week and now even though I have a great signal I cannot hear the XM radio on any frequency.
Turns out you need to install an antenna booster on your car's FM antenna. I finally found a salesman who understood the problem and was able to explain it clearly. The booster device clips to the base of your car's antenna (or sticks over a windshield antenna) and apparently enables the antenna to better receive the weak output from the newer XM Radios. Seems the FCC, in granting FM-band wide access to the XM radio output signal also required the output strength to be weakened. Thanks for the info folks.
Posted on Sep 23, 2008
I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
FM output
The low signal may be due to loose connection of the antenna cable
Aug 29, 2008 | Audiovox Xpress Satellite Radio Receiver...
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
To add to my request a manual for AWA 17cm DVD/CD/AM-FM Television Micro System
An FM transmitter is a portable device, which converts a specific audio output into an FM radio signal. It can be plugged into a CD player, satellite radio system, headphone jack, or a portable media player. One common use of an FM transmitter is to play music from an Mp3 player through the speakers of a car.
Aug 20, 2012 | Televison & Video
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
When i press the gas hard the car stops or lights turn off and on. i think its something with the transmition
have you had the battery and charging system tested? a faulty battery will cause all kinds of real goofy issues and youll spend all week chasing your tail. start at the battery.
Nov 08, 2009 | 2005 Pontiac Grand Prix
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
No audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Apr 06, 2009 | Marantz Audio Players & Recorders
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Audiovox Xpress Satellite Radio Receiver with Vehicle Kit Logo
275 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
