I just moved and have no idea if, or for how long, my fridge was on its side. It has been plugged in for over 12 hours and is barely cooler than room temp.
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
I would be careful using it. Chances are that it does not have enough freeon in it, and that will make it run all the time, it could catch on fire from the over heating of the motor.
Typically, the fridge gets its cool air via a vent from the freezer. If this vent becomes blocked, then the fridge won't cool. If there is nothing obvious blocking the vent (like a plastic bag) on either side then it is possible the vent is clogged with ice. To fix this, move your food to a cooler and unplug the fridge long enough for the ice to melt (12-24 hours).
Typically the fridge gets its cool air from the freezer via a vent. There is likely something blocking that vent like ice. Move your food to a cooler and turn off the fridge long enough for the ice to thaw (12-24 hours).
If this does not resolve the problem then dismantling of the vents for cleaning will be required.
Yes wait for like 12 hours to plug it in, then only run it for a few minutes and leave it set for an hour for about four times....
Yes it could damage the fridge but probably not...
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
No, it won't be harmfull if you be patient when you get it there. When you get the refrigerator set back up make sure that you wait at least a few hours before plugging it back in. This gives the oil in the system time to run back into the compressor before you run it. Have a good time moving I sure am gald that it is not me. It is a lot of work!!
