I have a Linksys router. 2. I have a Toshiba Satelitte Laptop, with a wireless card already built in. 3. I have internet access already on a desktop, but need it to be on my laptop as well! ( I need to be able to be IN a DIFFERENT room and still have internet on both computers )
    President:
  • 2,961 Answers
Assuming you have a wireless router, make sure you have purchased the correct one, as cable and dsl routers are different, as cable modems need to be connected to the router via a cable and dsl normally have a modem that can't be connected to a router, and you will require a modem/router.
You can only share a wireless connection when the line comes directly to the router and not through a pc, as the pc with the connection will have to always be on.
Posted on Aug 23, 2008
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Linksys rouder suddenly stoped alowing other computers net access
I would recommend upgrading the router firmware, if you have not done this already.
Download the firmware file from the Linksys website:
http://www.linksysbycisco.com/US/en/support/
Typically, the upgrade is done by pointing your web browser at the IP address of the Linksys router. Linksys should provide specific instructions at the site above.
Nov 01, 2009 | Linksys Wireless-G Broadband Router
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Bought a toshiba satel laptop and want to router it to dell dimen
You don't need a router for the laptop it has a wireless card in it already, buy a router for your home PC and I would buy a linksys with cap 5 network cables and wireless connections so you can use the printer off of the home computer PC. If you have high speed Internet you can request for a router for free with a wireless and cap 5-cable capacity.
Jun 21, 2009 | Toshiba Satellite Laptop
Is my problem the internet signal or the wireless router?
Howdy,
If you have been using this router/laptop for 3 years successfully and then all of a sudden it does not work, you may attempt to try an external USB wireless adapter. Does your T30 have 802.11b connectivity built in? It is not unusual for these to go out. Before you buy one check first to see if you can still access wirelessly at other hotspots? Or does the problem follow you around? If you can successfully connect at other hotspots then this is not the problem and it may very well be your router. Is there any way you can get a substitute rouer to test with before you purchace one? A friend maybe? It is probably one of these 2 issues. If you find your wireless is out on the laptop and you go to purchace a USB wireless adapter, go for a Linksys and make sure it is at least wireless "g" or "n" and not "b". And if you do not have enough USB ports then you may want the flat wireless card adapter that plugs in to the PCMCIA slot on the laptop. This can be Linksys also - I use this one (flat card) - "Wireless G Notebook adapter with SRX" Model Number WPC54GX. It is great and has speed boost. If your built in wireless on the laptop is bad, then any of these external adapters you choose to use will simply take over the wireless reception. Good Luck.
J
May 30, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless Internet
yes you can purchase the router
satellite?blobcol=urldata&blobheadername1=content-type&blobheadername2=content-disposition&blobheadervalue1=image%2fjpeg&blobheadervalue2=inline%3b+filename%3dwrt54g.jpg&blobkey=id&blobtable=mungoblobs&blobwhere=1193783379233&ssbinary=true
  • All-in-one Internet-sharing Router, 4-port Switch, and Wireless-G (802.11g) Access Point
  • Shares a single Internet connection and other resources with Ethernet wired and Wireless-G clients
  • Wireless data rates up to 54Mbps -- 5 times as fast as Wireless-B (802.11b), but also interoperable with Wireless-B devices (at 11Mbps)
  • Advanced security: Wi-Fi Protected Access™ (WPA), wireless MAC address filtering, powerful SPI firewall
May 02, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
