Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Can't find a roland adapter
Can't find an adapter for my Roland Piano keyboard
What's the keyboard model
Posted on Sep 27, 2008
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
Service manual for the roland piano kr375
Your best bet would be to contact Roland directly to obtain a service manual. Go to the Support link at the top of this page- Roland
Jan 15, 2015 | Roland Music
Are the currently manufactured Roland Home Piano series pedal assemblies compatible with the Roland HP237?
This wish an after market pedal, or the original 3's connector? If the keyboard is on when you plug and unplug that, it is likely due to a voltage reference getting confused. Usually when you get constant sustain then most likely a switch is stuck closed, or open, down there in the pedal. How these things work normally is that a pliable switch is opened, for sustain, or closed. It depends on the keyboard. Some keyboards have a setting inside them to accommodate both types of pedals, and some pedals have a switch to choose either. Your keyboard does not have a setting that I can tell, other than adjustments for a resonance option (nice feature). I am not sure the newer RPU-3 pedal is compatible, it seems to be for the newer models. If you are handy with a volt meter, then can check the cable's pins for a common, then a pin that changes with each pedal (use continuity mode, beeps when circuit is closed). Could be a piece of dust is in there, or hair or carpet stuff, and a good cleaning would fix that from blocking the normal function. Manual Link: http://media.rolandus.com/manuals/HP-237_OM.pdf
Aug 02, 2014 | Roland Hp337 Digital Piano
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
I have a Roland Rd600. Im just looking for some info and help on getting the best Real piano sound i can from this keyboard. I appreciate any help Thanks Glenn
Hi Glenn, Try "Grand" or "Concert Grand" if you haven't already. Roland is known for great piano sounds. I hope this helps,
Best,
Mark
Dec 28, 2010 | Garden
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
98 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
