SOURCE: UPS not charging
normally to diagnosis this problem you need a special diagnostics software.Nevertheless,the ups needs to know that battery is present before to give a charge current.
i will advice you see with a mge representative in your locality
SOURCE: Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
SOURCE: Toshiba M400 Battery 100% but when power disconnected shuts down
hi dear i dont think you can any test on this my addvice is take to toshiba service center ...
thnx
Most UPS's will check the voltage of the battery periodically when the UPS is running and all is well with the AC power. If the test returns a "fail" on the voltage of the battery, many UPS's will start acting strange. It sounds like this may be the case with yours. The batteries can be changed by removing the access door on the bottom of the unit. A phillip screw holds it in. Here's a link to the battery set: http://www.batteryinternational.com/cyber-power-cps1100avr-ups-battery-ups-batteries-f1.html
SOURCE: APC Smart UPS 1400
The sealed lead acid batteries in them have come down a lot in price now, see here for one on batterytrader, 12v 7ah sealed lead acid battery
To install:
