Question about Lexmark JetPrinter Z22 Color InkJet
Not printing very well
My lexmark z22 does print but not very good..when it prints u can barely see it and there are white lines going across the page.i did have the black ink cartrigde refilled and i dont know what else to do..please help...thanks ashlee.
  • ashlee29 Aug 23, 2008
    this printer was given to me and i did fill the black ink cartridge..it does print but u can barely see it..
    Sergeant:
    Champion:
  • 317 Answers
I have the same one at home, try using the cleaning mode from the utility menu. That helps out every time you change a cartridge.
Posted on Aug 23, 2008
Lines are visibile across the page every time i print something.Ihave tried changing catridges but makes no difference could you please give me some advice thankyou
If the cartridge is not the issue, then the printer itself most likely is. Usually lines appearing when you print is a sign that your printer is aging and needs replacement. If you've just purchased it it's probably defective. Otherwise, it's probably just getting old.
You might be able to check and see if there is any dust or stuff caught in the printer, if that's the case spraying it with compressed air to clean it might help. If not you should consider buying a new printer, or getting it replaced.
Mar 12, 2011 | Lexmark JetPrinter Z22 Color InkJet
Unable to get my Lexmark 4200 off the default setting of color, want to print in Black/White and select color if I want to print in color .
Good day! Here's an article in the Lexmark website that will show you how to use the Print Properties Dialog on the Lexmark 4200 series. It has some graphics to better understand the instructions. Just click on this link: http://bit.ly/bvMxnp . You should be able to come across Print Color images in Black and White option. Hope this helps. Good luck!
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have installed a lexmark z22 printer but it
Try the following check-lists
1.Initially ensure correct drivers are installed in the operating system you are using .This can be checked by seeing in the device manager or in the control panel-->printers and drivers option.
If drivers are correctly installed you will the printer symbol in printer options with the name of the printer.
Right click the printer and give test page as print
If the print is not working check whether the power cables and connecting cables are good.
Check the indicators in the printer does it shows any warning.if you have manual of printer you can verify from it
Mar 10, 2010 | Lexmark C533DN InkJet Printer
First print line print fades away across page,
The page size is off. Try readjusting it in your "printing preferences". Otherwise, if it is new, back to the store for a replacement. It really should not do that.
Sep 02, 2009 | Lexmark 2391 Plus Matrix Printer
Have a Lexmark Z22 printer that skips lines while printing
One of your cartridges is plugged up..take it out and gently remove any excess ink from each cartridge hole with a napkin and try again..
May 28, 2009 | Lexmark JetPrinter Z22 Color InkJet
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
CANNOT INSTALL Z22
llucola:
The spooler service can be started following these directions.
Go to start
Go to run
In the open box type: <cmd> without <>
When the command prompt opens
type: net start spooler <Enter>
This should say that the spooler has started successfully.
Jess01: A driver is basically a communication device between your print device, which is your hardware "meaning can touch it" and printer software that is the language that your print device and computer can read. Your USB cable let's the computer know that your printer is connected. The software is needed so the printer has the language to be able to print what you tell it to.
If you have windows 2000 or xp.
Go to this website.
http://www.nodevice.com/driver/Z22_Color_Jetprinter/get31830.html
Scroll down the page 'til you find Lexmark Z22 Color Jet Printer
To the right you will see "download"
Click the link.
Scroll to the bottom you should see "Please enter verification code"
Type the code in and click "download"
Click save.
The software should then be downloaded to your computer.
Go to the location you saved the printer drivers.
There should be a setup file.
Click on that.
The printer should then be recognized and you should be prompted that the printer is going to print a test page.
Nov 05, 2007 | Lexmark JetPrinter Z22 Color InkJet
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark JetPrinter Z22 Color InkJet Logo
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
