Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
Posted on Aug 23, 2008
My uniden dect 6.0 cordless is not compatible with Lingo phone service. I am able to receive calls but not make calls
  • Anonymous Dec 04, 2008
    im having the same problem. i can receive calls but cannot make calls. i does not allow me to dial the numbers. pls help
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Aug 27, 2008
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Anonymous
  • 39 Answers
  • Posted on Mar 17, 2009
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Anonymous
  • Posted on Aug 24, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
consultel1
george peters
  • 860 Answers
  • Posted on Dec 21, 2009
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Anonymous
  • 2992 Answers
  • Posted on Mar 27, 2010
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
Uniden user guide
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Out going message for uniden dect 6.o phone
Phone dect 6 on silent mode how do i correct and remove
Since you declined to specify the model of your Uniden DECT 6.0 phone, you may select it from the list beginning here to download a copy of the manual.
I have a uniden single 6.0 cordless phone, I cannot find the manual. The phone shows that it is on hold. I cannot dial nor receive calls please tell me how to correct this.
Since you declined to specify the model of your Uniden DECT 6.0 phone, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get a copy of the manual.
2helpful
How do I delete calls made and calls received on the Uniden DECT.6.0
That depends on the model of your phone. Please select it from the list beginning at
to get the manual.
Can not receive calls. Can call out, but incoming calls give a short beep and then a busy signal.
Is this a cordless phone or a land line. Have you tried another phone ?You might wanna talk to your tel service provider.
2helpful
2answers
I NEED A MANUAL FOR MY CORDLESS PHONE UNIDEN 6.0
Here's a link, scroll down to 'download now' and you can download to your pc. If this helps you plz rate this fixa. Thank you kindly.
http://www.generalmanual.com/Telephones/Uniden-DECT1560-3-DECT-6-0-Cordless-Phones.htm
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
