Question about Pioneer CDJ-800 Turntable
The CDJ won't load the disc!!!
Hey Guys,
My Pioneer CDJ-800 won't load any discs. The eject mechanism works cuz when I hit eject is the motor works and if I have a disc up to the slot hole, it'll push it up, but it won't grab the disc to load it. Any idea if this is quick fix? Or do I have to go get this repaired.
Thanks.
You have to get it repaired,no quick fix im afraid.
email: info@audiovisualservices.info for all dj equipment repairs.
Thanks.
Posted on Oct 02, 2008
Pioneer 800 mk1 eject disc when powers on
Well, the optical pickup is not able to read the disk. First off, did you use ESD protection when you installed it? If not, it may already be damaged. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Jul 22, 2013 | Pioneer CDJ-800 Turntable
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
When i put a cd in the cdj it won't read it and ejects it
This is more than likely a laser issue. Does it spin the disc up? The first thing the CDJ will do when you put a disc in, is look for a reflection of the laser, which tells it that there is a disc inserted. There should be a short pause whilst it does this, before it fails and spits the disc back out again. If this is the case, there is either dirt and grime on the laser lens, or the laser needs to be replaced. Normally I recommend replacing the traverse mechanism, which includes the spindle motor and laser assembly.
If this needs to be replaced, either ask for more help, or contact your local Pioneer Service Agent.
Hope this helps :)
Jaye
Oct 27, 2011 | Pioneer CDJ-1000 CD Player
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
Eject mechanism failure on cdj 400 ''E 9101''
did you find the motor and belt for ejection mechanism? try to replace that belt.
Apr 06, 2010 | Pioneer CDJ-200 CD Player
When my cdj turntable is powered on it begans to eject repeatedly even though there's not a disc loaded. I've attempted to correct the problem by restarting several times, adjusting the controls and using...
Your CD tray is damaged, or the loading mechanism/motor is damaged - or both. Unfortunately, not an easy fix. You'll need to take it to a service center for repair.
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Sep 14, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 Bad Laser
Yes, sounds like you have a bad traverse assembly (laser). You can replace it yourself, however, I wouldn't suggest it, as you need to calibrate the assembly after the installation, and remove a solder bridge (which keeps the unit safe during transport). It is a little complicated, if you don't have experiencing doing this type of work. Taking it to a service center would be your best option.
You can purchase the part HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 17, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800MKII
Any error codes??? you must provide some more info... is the screen blank? When you are trying to insert a cd do you hear any noise from the mechanism?
Aug 01, 2007 | Pioneer CDJ-1000MKII CD Player
Pioneer CDJ-800 Turntable Logo
269 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
