Question about Legend LA1490 - American Legacy Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier
Subs the subs came in a pre loaded box and there nominal impendance is only 2ohms, doesnt the xs2500 pheonix gold amp have the power? if not how would i wire up those mtx subs for them to work properly
    Novelist:
  • 100 Answers
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Posted on Aug 29, 2008
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
When I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
I'd suspect that the amp is operating into too low of an impedance and going into protection.
The 2200/2 is not rated to drive a 2ohm load when bridged (most 2-channel amps aren't) and when you connect 2 4ohm subs in parallel, the load is 2ohms. I'd run one sub from each channel.
Hope this helps.
Jul 26, 2009 | Power Acoustik BAMF2200/2 Car Amp
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
Pheonix Gold Xenon 600.1 power problem.
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Apr 11, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
Legend LA1490 - American Legacy Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier Logo
157 people viewed this question
Top Legend Car Audio & Video Experts
xxxxxx xxx
Are you a Legend Car Audio and Video Expert? Answer questions, earn points and help others
