SOURCE: Fisher and Paykel E522B refrigerator is not
Make sure air circulation is getting to the fridge side . Also check the evaporator fan and see if it is blowing.
SOURCE: THE TOP PART (FRIDGE) IS NOT COOLING
We had the same problem. The duct between the freezer unit and fridge is probably iced over - a design problem apparently. Allowing to completely defrost will solve.
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Testimonial: "which temerature censor ( there are three )"
SOURCE: I have a fisher and paykel E522B refridgerator and
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Testimonial: "I actually found little hex screws at the bottom of each of the handles. Once both are loosened a fair way the handle comes off allowing tightening."
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
