Question about Audiovox ADV12 Portable DVD Player
Remote won't work
I've also tried a universal remote. Is there any type of reset for the IR control?
I got the ADV, but I don't have the remote control, does anyone know about compatible remote control list, or universal code for that one ? I'm in Barzil - S?o Paulo, If there is some autorizd store, please let me know about it.! luizldg@ig.com.br
Best Wishes,
Luiz Antonio,
Posted on Sep 14, 2009
What happens if i disable IR
When you make the infrared sensor disabled, the TV won't response to any remote control there after.
Jul 14, 2012 | Televison & Video
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Toshiba Color Television 36A43 Lost the original remote and purchased a universal remote. Tried to program using all four systems to no avail. I require the universal remote code to program for this TV
Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
Jul 13, 2011 | Televison & Video
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
My Sony Bravia doesnt work with remote control, with any remote including universals
You didn't include the Sony Bravia model that you own - so I can't be more specific. If the TV is set up to use RF (radio frequency) codes instead of IR (infrared) codes; the universal types probably will not work. This is because most universal remotes are the IR type.
The remote included with your TV may have inadvertently be switched to send the codes as an IR type while the TV will respond only to RF type codes. It may also be that the TV was changed to respond to RF codes only. Either way, check your manual (or your TV menu settings) to see how to set the TV and the remote to work in the same mode.
If you can't find your manual, reply with your TV's model number - and if possible the remote's model number, too. I'll see what I can find that is specific to your TV.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 06, 2011 | Televison & Video
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
I have 722 and a ir/uhf remote. Remote is set to uhf. All was ok until about 2 weeks into use and remote does not work unless 6 inches from antenna. I tried wizard numerous times and resetting to ir and...
jholsinger1,
It sounds like this is TV 1 that you are having this problem with the remote, is that correct? What has changed from when the remote was working till now? Was anything moved like the TV/receiver? You may have some type of interference with the UHF signal. Without getting more specific information, I'm generalizing the trouble shooting steps. Would you clarify if it's TV 1 or TV2. Please post to this site and I will respond back to you.
Ray Calo
DISH Network
Jan 16, 2011 | Universal Remote Control DISH Network...
I have a nuwire for my remote controls for mulitiple items and i can't get it to work on my dish network system
romaneastwoo,
What type receiver is your TV connected to? Do you know your remote model number - located on back of the remote at the top (ex. 2 digit number 5.3 ir). The majority of our TV 1 remotes work in IR mode. If this universal remote uses UHF frequency, it will not work for the IR frequency. Please let me know your receiver and remote types and I will see if there is anything we can do for this remote.
Ray Calo
DISH Network - Executive Offices
Jan 11, 2011 | DISH Network IR Remote Control
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
the problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Sep 04, 2009 | RCA Universal Remote Control
Universal remote code
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotehome.shtml
Code 720# for my 26" insignia tv on me bell remote 3.2 IR - 137181 and it worked for me. Click on link choose the type of remote you have.
Good luck
Lapete
Feb 09, 2008 | Televison & Video
Audiovox ADV12 Portable DVD Player Logo
145 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
