Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore freezer The upright freezer door will not seal. The gasket apears in tack but even when you push it closed it will not stay closed. The freezer does not make that vacuum like sound when you close the door. Do we just need a new gasket or is there some other problem. There is no ice buildup or anything obstucting the seal. The motor and freezing action are working OK.
  • leroy2944 Aug 25, 2008
    freezer doorm closes but after 3 days closed ice and frost on top of inside door
  • 639 Answers
Hi Robert,
Happy to help.
You need a new door seal.
But they are not easy to put on properly
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
My gibson upright freezer is not freezing
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 30, 2012 | Frigidaire 13.7 cu. ft. / 388 liter...
PLFU2067DS4
From what you have described it sounds like you might be experiencing some form of sealed system issue, faulty defrost timer or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 15, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Stops cooling unplug replug starts up again
Hello Tana - Freezer might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why is water leaking from door seals
the seal itself may be bad. coat the seal lightly with lipstick (your choice of color) close door GENTLY then open and check coverage and evenness of lipstick. any gaps will show lack of seal.
Aug 27, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
WHAT IS THE PROCESS IN REPLACING THE GASKET ON MY KENMORE UPRIGHT FREEZER
If it is a push fit gasket it simply pulls out and the new one pushes in to the groove. Warm in hot water before fitting to ease it in. If the seal is part of the door, you have to replace the door as a complete assembly. Rare models have doors that can be taken apart and reassembled with a new gasket fitted but i don't think Kenmore is one of those.
Apr 19, 2012 | Kenmore Freezers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Door won't close stay closed or seal
check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Feb 01, 2010 | Kenmore Freezers
Kenmore freezer
if the gasket isn't torn and the gap isn't caused by a door hinge problem you might try putting some vaseline on the door seal. If that doesn't help you may have to replace the seal.
Dec 30, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
184 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
