Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Agitator Shaft in Planetary
The agitator shaft (the part that mixes) is slipping.  I can get the top off and see the gears above the shaft, but how do I safely remove the planetary portion to expose the worm gear that is probably (I'm guessing) broken?
  • 118 Answers
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
Posted on Nov 30, 2008
I have a Hobart Kitchenaid K45SS mixer and want to know how to remove the agitator shaft from the planetary so I can paint the planetary.
To do this, the whole planetary news to be removed. Use a light hammer and 5/32" pin punch to drive out the pin holding the planetary in place. Then use two flat-blade screwdrivers placed on opposite spots under the planetary and push down on the screwdriver's handles. This will force the planetary up and off the central drive shaft.
Now you can remove the agitator drive shaft which is held on (depending upon the age of your mixer) by a screw or ring atop the gear at the end of the shaft.
Re-assembly is the reverse process. Be careful to line up the pin''s hole in the planetary with that in the drive shaft so that the pin can be driven back in place.
The Service Manual can be downloaded from:
Jun 07, 2017 | KitchenAid Food Mixers
Professional 600 575 watts beater shaft is loose
If the beater shaft that you attach the beater to is loose in it's housing, then you will need a new planetary for your mixer, it is a relatively easy fix to make, but you will have to order the part before you can effect a fix.
The 600 model has the center shaft attached to the planetary by means of a heat pressure press in. Which means that when the colored rotating part starts to come loose that you have to replace the whole planetary piecec994bebd-6a21-41c8-821e-a90ec9e3ea14.jpg
the piece that the beater attaches to is called the agitator shaft and it will need to be removed and put on to the new planetary when you install the new one. If the agitator is actually the piece that is loose then you need a gear at the top, a pin underneath of the gear, or a snap ring that holds the shaft together in the planetary housing. Go to the kitchenaid address listed here>>
when the page opens look on the left side of page and fill in the proper model number (it is on the bottom of your mixer on a white tag), the page will give several choices go to the parts list section and click on that choice for your model number, (you will need the proper part number to order the correct color for your mixer, by following the parts list diagram you will see that there is a very understandable process that you can follow to open up the mixer and replace the planetary, hope that this helps, let us know if you need assistance or if this answered your question
Apr 17, 2013 | Food Mixers
Professional 600 575 watts 6 qt. beater stem is loose and lets beater drop onto bowl.
b68be83b-c0cb-45d6-8d74-337f1cf098bd.jpgThe part you see is called the planetary, it has two shafts, the long one is called the center shaft and if it is falling off you need a new planetary, the second shaft (shorter) is called the agitator shaft (the beater attaches to it, if this is the culprit then1 you are not attaching the beater correctly2 the locking pin that the beater attaches to to hold it in place is missing3 you have way too much "gunk" build up on the agitator shaft and the beater is not attaching correctly4 if the beater falls into the bowl with the agitator shaft still attached you have three additional problems a) the snap ring a top the agitator shaft has broken off or come off which in turn means that
b) the gear at the top of the shaft has come off and may very well been knocked around and possibly damaged beyond future use which means that you will need a new one and also
c) the shaft pin that holds the agitator gear in place has come out or been broken also
the fix is easy and your parts cost $ will be from $30.00 to $80.00 dollars depending on which parts you need. Now before you get palpitations, cost are listed as a possible need
1 new planetary $30.00, you may not need
2 new agitator shaft and gear assembly $27.00, pretty sure that you need but maybe not
3 new gasket $6.00
4 new gear grease $6.00 KA says 2 oz. (don't buy a 2lb (26.00 bucks) can when you only need 2 oz).
Without more clarity or a picture I can't help further. but before you start tearing you machine apart go to the KA website and get a parts list for your mixer
let us know how you fare on this or better yet get us a little more info and we can help more.
Apr 17, 2013 | KitchenAid KP2671 Professional 6 Series...
BBeater scraping back bottom of bowl
Is the planetary still off before the taper pin is in place?
It's a shot in the dark but if everything lines up, I can think of two possibilities:
1. The taper pin in backwards, and
2. The shaft hole in the planetary is out of round.
Mar 20, 2017 | Hobart N50 Stand Mixer
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at
Download the following Kitchenaid Service Manual:
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I need to replace the rotatating column on my KitchenAid mixer.
Hi ALLENJUJU. To replace the agitator shaft will require a significant amount of extra effort, but will be well worth it in terms of gratification and reward for being able to successfully do it yourself. First, I’ll assume your mixer is no longer under warranty. Second, I’ll assume you have your Repair Parts manual on-hand. If you're lacking one, you can download a PDF version from the KA website at:
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: “Case Gearing And Planetary Unit” which shows you an exploded view of all the mechanical parts and assemblies for your mixer.
I highly recommend the following website that provides you step by step instructions with pictures (worth every bit of a 1000 words) to gain access to your planetary housing and agitator shaft. The mixer displayed is a different model (tilt-up) than yours, but the ‘insides’ are the same.
It would be helpful to have the following tools available as you begin to disassemble your mixer: a flat screw driver, a small Phillips screw driver or a punch drive, a pair of retaining clip/ring pliers, and a hammer.
You will need to remove the Planetary Drip Ring (Illus. No. 42) and Pin (Illus No. 25), which secures the Planetary Housing (Illus. No. 33) to the Center Vertical Shaft (Illus. No 19). (See pictures 6, 7 & 10, 11 from the link).
You’ll need the punch drive or small screw driver with a smaller diameter than the pin, a hammer, steady hands and plenty of patience. Rotate the planetary housing to expose the retaining pin with the vertical (center) shaft.
After removing the Planetary Housing, remove all the residual grease from the 18 tooth Agitator Shaft Pinion Gear (Illus. No. 47), which should expose a Retaining Clip (Illus. No. 61), which will need to be removed. With the Retaining clip removed, the pinion gear and Shim Washer (Illus No. 45) should easily slide off the top of the agitator shaft and you should be able to pull the agitator shaft down through the planetary housing bushing.
Take your new, replacement agitator shaft (be sure you’ve got the lower groove pin ordered, too, and insert through the bottom Planetary bushing. Replace the shim washer, 18 T Pinion Gear and Retaining Ring. Grease up the whole works with new grease, and reassemble the opposite of how you took it apart.
Here are five potential online vendors in no particular order:;;;; and (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have a Kitchen Aid Professional 600, 6QT, 575 W mixer. I went to use it and the beater and the assembly that it attaches to dropped down in my mixing bowl! What holds this assembly up? I did not find any...
Hi DASCO474. This is not good... From the symptoms you describe your mixer’s Agitator shaft is dropping from the Planetary assembly. Something has caused the retaining clip and pin to break so allowing the agitator shaft to drop.
Fortunately the inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at:
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.)
Turn to pages 4 & 5 entitled “Case, Gearing And Planetary Unit” for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 28, Planetary Assembly and Illus. No. 34, Agitator Shaft. The parts which hold the Agitator Shaft within the Planetary are Illus. Nos. 9, Retaining Pin and 30, Retaining Clip. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Agitator Shaft gear you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove the Transmission Housing (Illus No. 4) and remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 7, 8, 9 & 10, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 9) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 11). With the Planetary removed, you should find all the parts which slide on the Agitator Shaft (Illus. Nos. 30, 31, 32, & 33) and pieces of the retaining pin, which should be loose in the base of the Planetary.
Besides ordering a new retaining pin and clip, you might want to reorder the Transmission Cover Gasket (Illus No. 6), too. You’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check for any other unseemly wear and tear on the gears, too.
Here are five potential vendors in no particular order:;;;; and (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 03, 2010 | Food Mixers
Hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Sep 25, 2009 | Hobart N50 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
400 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
