Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Picture ripples Ripples appear in the image when photographing an object with fine plaids or stripes why is that and how can i fix it?
    Sergeant:
  • 255 Answers
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Posted on Aug 31, 2005
Why did moving green horizontal line appear on screen and won't go away?
hi,
if your cam is equipped with a viewfinder how the picture show, if clear, the LCD is faulty, if in both screens the line appears there may be problem in the circuit, the capacitor on the board must be tested, if it is weak the ripples will appear on screen.
Jan 09, 2016 | Video Cameras
Just bought the above, and anytime i try to connect the arial,it says i have to position my antenna correctly, no picture or sound.
It is probably referring to the antenna alignment
if it is an external antenna then it has to point in the direction of the transmitting aerial for it to work and allow the auto tuner to lock in
imagine the transmission as ripples in a pool the antenna has to be at right angles to the ripples or it will not pick them up
The transmission is in two sections
one section is picture and the other is sound and they act as a piggy back for each other to operate and that is why the antenna has to be aligned correctly.
May 29, 2015 | Televison & Video
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Sony 46WT500 green beam ripple
Its the convergence output ICs or the solder connections beneath them.
michtech
Feb 19, 2009 | Sony KP-46WT500 46" Rear Projection...
My lcd tv picture doesn't seem right.
spurious oscillation in video circuit
Feb 08, 2008 | Televison & Video
Ripples in the edges
It's an inevitable consequence of using a low resolution jpeg. Try setting your computer monitor to VGA resolution (640x480) and you'll make a similar mess of images it displays - only worse, because the large screen blows up the image. You should use a higher resolution setting and invest in a bigger memory card for the camera if need be.
Sep 13, 2005 | Konica Minolta DiMAGE F300 Digital Camera
Ripples appear in the image when photographing an object with fine plaids or stripes. Why is that?
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
152 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
