SOURCE: my printer won't turn on after a power failure. beware spam number below
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
SOURCE: I have installed Windows 7 now How to connect HP
When you installed Win7, did you upgrade or did you do a Clean install? If you performed an upgrade, you may have the problem with older conflicting drivers and services. Read this to see what I mean. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
SOURCE: Service manual for a Brother HL-6050DN Laser Printer
You can get the Service Manual for your printer by clicking on the Link below.
http://www.smpcshop.com/HL-6050-HL-6050D-HL-6050DN-p-4010.html
The price of $9.95. Thanks
SOURCE: Brother HL-6050DN Printer gives "replace laser sca...
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
