Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Beater bar on - KitchenAid KP2671 Professional 6 Series Stand Mixer
  • proveritate Sep 09, 2008
    Unplugging the machine will not help. There is a gear problem and I need to know how to get to the gear so that it can be replaced. I need to get to the gear that moves and spins the mixer bar.
  • 1,512 Answers
Hi
My wife owns one of these, she calls it here Ferrari(because its red maybe).They are built tough, and gear breakages are caused by overloading the machine. You can get your parts from here
The gear that's failed is probably the fusegear, aptly named as it fails when the machine is overloaded. Use the exploded view to locate the part you require and away you go. They are not too hard to work on. Oh, and don't be fooled by the Whirlpool brand, they just re badge their products, so it is a KitchenAid.
cheers
robotek
Posted on Sep 10, 2008
  • Graeme Ross
    Graeme Ross Sep 14, 2008
    Hi again, how did you go with sorting the problem.
    robotek
    Brigadier General:
  • 5,158 Answers
The gear is actually a belt. or should be. place the head (where the beater bar is located) upside down so the bar is actually up. remove the screws around the base where the bar is located... it will come apart (look around the edges for any tabs holding the two pieces together. once you have the two parts apart... you will see the belt on one side of the bar. unless the belt has melted you should be able to locate a part number on it.
Replace and reassemble and you are good to go...
Robert
if you will provide me with the brand and model number i'll find you the replacement number
Please rate this solution if it is suitable.
thanks
Posted on Sep 09, 2008
  • Roberta Smith
    Roberta Smith Sep 09, 2008
    please ignore my suggestion completely ... thanks.... beater bar made me think you were referring to a vacuum cleaner.
    My apologizes
    Robert
  • 3,037 Answers
Here is a page with replacement parts and the second link is to a service manual that should be of great help in order to disassemble the mixer. Let me know if you have any questions while taking it apart as I know the manual does not list your specific mixer in it but it is the same general design.
http://www.mendingshed.com/kagears.html
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
  • 535 Answers
U have to go with a professinol service man
Posted on Sep 08, 2008
    Genius:
  • 1,689 Answers
Lets know what the exact problem is and maybe we can search for a solution for it.
    Master:
  • 521 Answers
Unplug for some time n then replug and on the switch.see wether it solves ur problem
Posted on Aug 23, 2008
  • KitchenAid Master
  • 19,396 Answers
Please give more details
Old Kitchen Aid classic (25+), new KA-TH beater bar and suddenly the bowl won't stay mounted. Is it the beater bar, the mounting or something else?
You may need to adjust the head height if the new flat paddle is a bit bigger than the original. When you have the head lifted up with beater out of the bowl you will see a single slotted screw where the head hinges on the pedestal. Anti clockwise to lift the head up, clockwise to drop the head lower. Paddle should just clear the bowl with head down & motor running.
Oct 25, 2013 | KitchenAid K45SS Classic Stand Mixer
Old classic Kitchen Aid (25+), new KA-TH beater bar and suddenly the bowl is getting knocked off the mount when making cookie dough. Is it the new beater, the base or something else?
Adjust the head height, with the motor raised look in where it hinges. There is a flat head screw there, anti clockwise a bit to raise the head up a bit and stop it banging about on the bowl. Just enough to stop it.
Oct 25, 2013 | Food Mixers
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
How to attach a icecream maker KICA0WH to KitchenAid Artisan Series KSM156 that has a cap on the beater shaft. In the manual it shows how to attach it to the mixer with spring and no spring but does not...
After the bowl has been frozen you attach it to the base. Then you take the part your asking about and attach it where you would put a beater or whip. The trick is to make it spin and the notched part stay in the "center of the circle". You don't use the top front of the mixer. I had to practice without the bowl and beater bar to make sure I had it right.
Jan 04, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
Please help me get the beater blade out of my mixer!!
your going to have to do some quik jerks, I have seen this plenty of times, has beater bars ever been removed or how long have they been sitting
Nov 25, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
I have a grey film on my flat metal beater anyway to remove?
Gray film may be a result of tarnishing. The metal beaters are made of a burnished aluminum material. The burnished aluminum may not be washed in a dishwasher, cannot be left to soak in a sink, and must be towel dried immediately after washing as opposed to being air dried. If this has been done incorrectly, this may lead to tarnishing of the beater, which can be described as a "grey film."
Jun 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Stand Mixer
Model H was discontinued in the 70's. You might find beaters either directly from Hamilton Beach or on Ebay. There aren't many small appliance repair shops any more, everything now, is considered disposable.
Jan 02, 2009 | Hamilton Beach 950 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
54 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
