Bluetooth activation my sgh - e900 will not activate the bluetooth.when i try to turn that on it loads forever then says ' bluetooth activation failed '.anyone know how to get around that ?
You can't post conmments that contain an email address.
In standby mode, press Menu. Highlight Applications and click Select. Highlight Bluetooth and click Select, or just press 4. Highlight My devices and click Select, or just press 2. Put
your remote device into pairing mode. You can find out how to do this
from the manual that came with the device. When the device is in
pairing mode, highlight Search new device and click Select. If Bluetooth is not activated on your G600, you'll be prompted to switch it on. Click Yes. The
G600 will search for all the Bluetooth devices in the proximity. The
type of device will be indicated by the icon to the left of it, so you
can clearly see if the device is a PC, a phone or a remote headset. You'll
be asked to enter the PIN number to connect to the device. This is in
the documentation that came with the remote device but if in doubt, try
1234 or 0000, as these are the most common PINs. Once connected, the device's icon will turn orange on the My devices screen, and when you press the red End call key to return to standby mode, you'll see the headphone icon on the top row of the screen. Your
headset will now be paired permanently with your G600. Switch the
device off to disconnect it, and next time you switch it on the phone
will connect automatically, providing your Blueooth is activated (go to
Menu, Applications, Bluetooth, Activation, On to activate Bluetooth).
My apologies for the copy past guide, I have never used a samsung phone.
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
i hav the exact same problem but with my ted baker phone. . any1 no how t fix it?
