Question about Sewing Machines
Tension problems (?)
Help! My sewing machine is wacked out! I was trying to sew and the thread kept breaking from the top stich and the bottom stich became loose and tangled in the bobbin area. I would only be able to sew about an inch of fabric before the problem started. The needle would get stuck and not move...and I would literally have to get needle nose pliers out to unsnarl the thread under the needle...what a mess! Not sure if I am explaining this right...I have an older model that has never given me problems...I bought this one in either '94 or '95 and have sewn with it more as a hobby now I am doing a lot of crafting with it. I do occassionally use either rabbit fur or light leather but that has never been an issue until just a few days ago.
  • cypaez Apr 21, 2009
    I have tried to adjust the tension so many times. Whether I loosen it or tighten it, the thread keeps breaking.
Well, I could have written this. I bought a used model from a repairman about a year ago. I have a Model 537FA and I'm going to throw it out in the rain leftover from TS Fay if I don't find some kind of help. :) I'm thinking it's a tension issue, but I can't seem to find a fix.
Does your tension on your top thread sometimes tighten to impossible to move in the middle of sewing. I know that mine does this and it causes the top thread to break. I don't know what's causing the bobbin mess.
Maybe someone will help us? Please!
Posted on Aug 24, 2008
Why would that thread break?
Hello, Pat -
Which thread on your sewing machine are you referring to? With either the top thread or the bottom (bobbin) thread, the problem is most likely due to the tension.
Another reason for the top thread breaking could because the machine is not threaded correctly.
If you have the owner's manual for your sewing machine, check it for the settings for the top thread tension and for the correct threading. Also, check the manual for information on the bobbin (bottom) tension.
This web page gives some generic information on sewing machine tensions:
https://www.thespruce.com/easily-adjust-sewing-machine-tension-2821432
Another option is that you are using old cotton thread to sew with. Over time cotton thread deteriorates and breaks easily. I only know this from personal experience. :)
Jan 06, 2018 | Sewing Machines
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
How do I stop my tread from popping on my Brother (17 stich) sewing machine?
Breaking thread? Presumably the top thread? AVOID old or bargain bin threads. The upper tension is too tight or the thread is not properly seated in the tension disk, the needle is defective or the needle, needle eye/scarf is not the best choice for the fabric/thread being used, there may be a snag in the bobbin area that is catching the thread. Make sure the thread is not catching on the spool's thread notch.
Why Does My Thread Keep Breaking While Sew
Sewing Machine Problem 1 Thread Breakage
Why is my thread breaking
Dec 07, 2016 | Brother Sewing Machines
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
I have a White 7140 quilters sewing machine. I can't find the manual and I am having trouble threading it. The stiches are coming out loose on top, but ok on the bottom. I have tried adjusting the...
try http://www.singerco.com/accessories/instruction-manuals and search by typing in your model number. I couldn't see it there but there are other white machine manuals there so maybe one will give you help with threading. It sounds like the bobbin thread is not under tension, usually if the top is loose it is the bottom thread which is not tensioned and visa versa.
May 30, 2011 | Sewing Machines
Good Morning: My wife has a Husquvarna Viking 320 Electronic Sew Easy. I have tried to re-work the bobin and the thread through the needle. When she stiches the hem on a pair of blue jeans it stiches...
since you are doing jeans it can be on either side so lets start for the beginning, rethread the top thread making sure that the thread went through the upper tension, second remove the bobbin and make sure to thread it through the lower tension(there is a spot on the bobbin case for the thread to go through for there to be tension on the bottom) if the thread on the bottom pulls really easy by hand like there is no resistance then take it to a local dealer and have him adjust it if it feels like there is a pull do the same with the upper thread put the foot down and try to pull the upper thread(don't break a needle) if it has tension adjust the upper thread tension tighter
Oct 19, 2009 | Sewing Machines
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
Stiching
It sounds like a thread tension problem. Find the knob for the tension and play around with it (look for instructions in the manual). If that doesnt work it might be the bobbin thread thats too lose in which case I would take it to the store or a repair service and have them show you how to do it.
Jan 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
214 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
