Question about GE Microwave Ovens
Is the 1.1 cu ft 1100 Watt model: jes 1139bl sold by Home Depot the same as the 1.1 cu ft 1100 watt model sold by Lowes ? If so, what is the model number of the lowes unit ?
Microwave dosen't power up at all ,changed the fuse still nothing
only one year old
Posted on Feb 03, 2010
  • GE Master
  • 9,086 Answers
A quick check of the Lowe's Web site show the following GE 1.1 cubic foot microwave models:
JES1142SJ
JES1139WL
JES1139BL
JE1160WD
JE1160BD
If you still have any doubt, I'd call Lowes.
Posted on Aug 24, 2008
MMV6180WS ONLY WARMS THE WATER
Assuming your power outlet is putting out the proper voltage (about 110-125VAC) then I would suspect a bad magnetron.
You should have at least a year warranty, so I would contact Maytag (see your owner's manual) for a free repair.
Jan 09, 2013 | Maytag MMV6180WS 1.8 cu. ft. 1100 Watt...
What is the size of Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK?
The of the Haier 700 WATT MICROWAVE TOUCH 0 7 CU FTBLK is 17" W x 10 3/16" H x 12 7/8" D.
Jul 15, 2012 | Haier MICROWAVE TOUCH
How much does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weigh?
The Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weighs33.1 lbs (15 kg)
How many power levels does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK have
The 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK has 10 powerlevels with electronic touch controls.
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Power cord
If you are referring to the main power cord then you should be able to purchase one at Home Depot/Lowes of most local hardware stores... make sure you get the current rating off the tag on the appliance.. 15Amp or less can use a cord size of 14 gauge.. you should use a 12 gauge for any appliance requiring up to 20Amps ( in your case ..1100 watts minus losses within the system should allow you to use 14 gauge power cord.)
Sep 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
1100 watt diplomat microwave
Please reply back with your brand and model number so we can help you.
Aug 20, 2008 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
149 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
