Question about Olympus Camedia E-20N Digital Camera
Batteries When I install my AA sized batteries into the battery holder they do not fit properly, they appear
    Master:
  • 852 Answers
The E-10/20N battery holders are designed to fit the longer type CRV-3 lithium batteries and conventional sized AA NiMH batteries. Once installed into the battery compartment the AA sized batteries will make an electrical contact with the camera
Posted on Aug 31, 2005
SOURCE:
I have a SimpleHuman dispenser that requires 4 AA batteries and cannot tell how to install them. They go two on one side and two on the other, but which is which?
with batteries , the flat base goes against the spring in the holder
there is generally a imprint under the battery in the holder which shows the battery direction to be installed
Aug 25, 2018 | Cameras
Tip
Turn AAA batteries into AA batteries in emergancy
all you need to do is roll up some tin foil into a flat circular shape the size of the battery that you need,circomfrence,not the actual size of the battery,put it against the spring on what ever gadget you need the batteries 4,then push the little AAA battery on the tin foil so it fits tight into the slot where the AA bigger battery should be and WALLA, sorted.your gadget should now work,and its the same principle with all batterys.
on Oct 01, 2010 | Toys
It asks for 3 AA batteries and I can't even fit 2 AA in it
its so not true instead try the fatter batteries maybe just one would do it
Mar 23, 2013 | Electronics - Others
Camera keeps saying to replace batteries even though new ones that have been checked with a meter and are OK are installed.
Are they the correct type of batteries? Use only AA-size Alkaline or Canon AA-size NiMH batteries.
Dec 15, 2010 | Canon PowerShot A540 Digital Camera
What batteries do i need to put in metz 45 battery hplder
AA Size Alkaline manganese batteries better for 45 Battery Holder.
H.D.Shirantha
Aug 21, 2010 | Metz 45 CL-1 Flash
Cant find batteries I live in Georgia
Depending on the battery holder, you can use AA, AAA, lithium.
If you have lithium battery holder, buy AAA battery holder or AA battery holder from eBay.
May 05, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Wair can i get a pro 75 battery from
The battery pack for your scanner, Radio Shack item 23-288, is out of production and I could not any source that still carries it. You can, however, power the scanner using six size AA batteries. The black battery holder that came with the scanner is for standard, non-rechargeable, alkaline batteries. The yellow battery holder is for rechargeable NiCd or NiMH batteries. If you don't have the AA holders you should still be able to pick them up from Radio Shack.
BillB
Jan 30, 2010 | Radio Shack Pro-95 Handheld Scanner
Weird battery size
use the AA batteries thats what i use and it still comes in and out
May 04, 2008 | Directv RC32RFK Remote Control
Weird battery size
try code 00001 or 00002
May 04, 2008 | Directv RC23 Remote Control
Type of batteries
You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia E-20N Digital Camera Logo
112 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
