Question about Sport & Outdoor - Others
Patio heater won't lite
I have a patio comfort patio heater model pc-02. it won't lite we cleaned the pilot hole and gas doesn't seem to be getting to the pilot.
    New Friend:
  • 182 Answers
There is possibly a spider web or wad of web blocking the gas flow between the valve and pilot.Take the line off between the valve and pilot and blow it out with compressed air and it should fix the problem.
Posted on Sep 11, 2008
Frontgate patio heater, serial number 01A02 0023562, model number SRPH02, cust number SHCDPH, pilot light won't light (checked gas tank already)
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
May 18, 2011 | Frontgate Stainless-Steel Outdoor Patio...
Hi, i have a big buddy heater. the pilot lite doesn't extend out to heat the thermocoupler. i have taken it apart & cleaned & blew out the pilot assy tubes. i can hold a liter to the coupler and i...
It's easier to replace the entire Pilot Assembly. The Part Number is 78422 and you can order it direct from Mr. Heater. For parts call 800-251-0001. It should run about $30.00.
Hope this helps you. Please let me know.
Apr 08, 2011 | Mr. Heater Big Buddy Heater
Heater wont lite up, but pilot light does
Sound like it may be your thermal coupler.
Aug 02, 2010 | Endless Summer 1501 Patio Heater
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
Gas doesn't seem to flow
The easy fix is a new regulator, if it is not the regulator you probably have a blockage in the pilot assembly. You have to take the head apart ot find and clear the blockage. If you are not comfortable with this, hire a service tech.
Jul 04, 2009 | Endless Summer 2009 Open Flame Patio...
GAS is to getting to ignitor for my patio heater model # 385.001
I assume you meant gas is not getting to the ignitor, take apart the head, if you are comfortable with it, and check for a blockage in the pilot assembly. If this does not fix the problem, try replacing the regulator.
Jun 24, 2009 | Rta International Patio Heater
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Patio Heater won't light
I would say you need to clean the burner.But make sure to turn the gas off first.
Mar 14, 2009 | Water Heaters
Charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Oct 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Sport & Outdoor - Others Logo
324 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
