Question about Sega Saturn Console
Console not reading disk
My sega saturn will not play the games it said that it is reading the disk then nothing happens. i also noticed that the disk is not spinning and and there is a red light that keeps blinking by the word access. pleas help i just got it and would like to play it .
  • retrodude Oct 22, 2008
    my games will not play
    Problem Solver:
  • 14 Answers
Increase the Laser Lens voltage by screwing the orange voltage screw clockwise 35 degrees. this orange laser lens voltage screw is located above the laser assembly inside the console. You will have to take the case off the console.
Posted on Feb 01, 2010
  • 148 Answers
Well...what can i say....it should be a laser unit problem, open your saturn and pull the flat cable and reconect again...try laser adjust..or it can be more easier than you think..try to check the Sensor button ,if it´s broken, it can´t activate the laser unit, so that´s why it´s not reading...
Sorry my bad english...if the problem persists call me in msn:
v4ndre@hotmail.com good luck!
Posted on Dec 04, 2008
I have a sega saturn that plays games just fine but will not play the background music to some games and will not play music cds. Any ideas?
Dirty laser, failing laser. I'd try to clean the lens in a circular motion with a DRY q-tip.
Let me know if that works ;)
Nov 12, 2010 | Sega Saturn Console
Put game disk in but game dosent play, goes dirrectly to settings such as time,date,ect
Sounds like the CD tray is not closing. Did you replace your battery? The battery is called a CR-2032. You can get this kind of battery at most stores that sell watch batteries. Take off the back panel and remove the battery. Insert the new one, replace the cover, and test it. If that didn't work, try opening up your Saturn by unscrewing the 5 screws on the bottom. Turn it over an then check the top-left corner, next to the part you plug your power cable into. There is a small switch that the CD cover presses on, try holding it down while you turn it on with a game in it and the top half of the case off. The game should spin and play. If you tape it down, it should work. Put the Saturn back together and there go, you just fixed your Saturn.
Oct 21, 2010 | Sega Saturn Console
Sega Saturn doesn't boot correctly. Can't play games.
This could be a situation where the Laser Lens voltage is off and it is not reading CDs. I have had this before.
You will have to take your case off, and look for a little orange "screw" or "dial" which is just above the cable that connects the laser assembly to the circuit board. It might have a Philips head looking top.
Make sure the system is off and unplugged before doing this.
Turn the orange screw approx 35 degrees clockwise, and the reassemble the system. This should give the laser enough juice to start reading the discs again.
If this is not the solution, it is possible your clock battery is dead. Buy a new CR2032 3Volt battery from wal-mart or your local watch store, and pop it into your top right (on the back of the system) compartment to fix this.
Good Luck!
Jan 21, 2010 | Sega Saturn Console
My Sega Saturn is acting weird...
try cleaning the glass laser eye with rubbing alcohol and cotton swab. This should fix the problem
Jul 18, 2009 | Sega Saturn Console
Difficulty in setting up sega saturn
Uh... what kind of tv cord are you using? Does it hook up to the cable or is it just the Comp. Video? (Red, white, and yellow plugs) If it hooks up to the cable than the RF unit(a.k.a.-the tv cable) is probably shot; buy a new cable (you can find them on ebay). If it's the other one, it still may be broken, but it's less likely. Just try replacing the TV cable and if that doesn't work, just buy a new system.
Feb 10, 2009 | Sega Saturn Console
Disk is not read...
the game might not have been printed on the cd it happens, try to get another disc of the game. it should work
Sep 03, 2008 | Sega Viking: Battle of Asgard for...
Sega Saturn Games will not boot, games show up as audio cds
I know what's causing the problem--the spindle motor for the CD's doesn't spin fast enough to read the disc properly; this usually happens when the system gets hit too hard or is dropped. This causes games to recognized as audio CD's and also causes the tracks to play improperly (there will be complete silence when a track is played and possibly some static at the beginning and the cubes an the sides of the display will be distorted and blown up.IF THIS DOES NOT HAPPEN THEN DO NOT ATTEMPT THIS.)Before starting, make sure the system is plugged in, there's no controller connected, and the system is NOT hooked up to a tv. Okay, now this is where it gets complicated. first, take the top of the system off and locate the disc drive switch. Depending on which model your console is, it'll be in different places. On the newer model (the one that has a PC board on the top cover), it'll be on a small PC board on the opposite side. On the older model (the one that has all the PC boards on the bottom), it's sticking up out of the metal plate between the two PC boards(the little clear plastic thing with copper plates inside). Either way, the switch needs to be held down or taped down.(I suggest taping it, but it may not work with the older system.) There are a few little variable resistors (little upright disc-shaped things) on the top left corner of the exposed circuit board (the one with the CD lens on it). Try adjusting those with a small flat-head screwdriver with the system turned ON and a CD on the spindle. Be CAREFUL--do NOT touch the CD while it's moving and keep your hands away from the PC board on the left--It WILL shock you. Adjust the resistors untill the CD spins the fastest. If the CD stops spinning, pull off and then replace the tape. If it doesn't spin at all in the first place, check the tape. Once you get it spinning as fast as possible, hook the system back up to your television WITHOUT replacing the cover. If it reconizes the CD as a game, your done and you can close it up. If it thinks its an audio CD or doesn't read it at all, the resistors need more adjusting. This work can be very trying and dangerous; this method can also ruin your system, but it's the only way to make it work without replacing any parts, but it DOES work. If you have any questions, ask me.
Apr 06, 2008 | Sega Saturn Console
Video Game Consoles & Games Logo
874 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
