Question about Kenmore 22422 Top Load Washer
Kenmore 24622300 My washer will not run with clothes in it. If I empty it out, unplug it and wait 10 minutes, it runs just fine empty. I'm assuming there is some sort of mechanism in the agitator that senses weight? Just guessing... This thing is only 3 years old so I'm looking for any ideas on what's wrong and how to fix it?
    Novelist:
    Champion:
  • 261 Answers
Try this, grab the agitator and turn it back and forth,machine off. It should feel free one way and grab as you reverse the motion, if not your agitator dogs are worn out. The fabric softener cups lifts off exposing a clear cap that when removed you will see either a 7/16 or 1/2 in bolt that allows the upper portion of the agitator to be removed. Then the guts will come out and there are four pieces retained by a ring , a supply house will have a ton of these.
Posted on Aug 28, 2008
Kenmore model 119 24622300 Heavy duty 2 speed washing machine....The machine was in mid wash cycle and completely stopped. Although we have emptied the clothes and water out manually (it would not drain),...
the first three is 110 on your model number,not 119.lift the lid up around two inches and close it down,do this a few times,if you don't hear a clicking sound the lid switch is broken,part number 3949238.if that's ok when the washer is in spin does the motor run,if it does you broke the motor coupling,this is located behind the motor,let me know what you find and if you could answer the questions i asked i can help you out better
Oct 08, 2010 | Kenmore Washing Machines
My washer is not working it begins to spin stops and has the letters LE appearing.
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
May 27, 2008 | LG Washing Machines
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Frontloader door keeps breaking
Call your retailer directly to make you whole.
Video tape the events and send an email to Kenmore.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore 44102 Front Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
No Power and will not open.
Try unplugging the machine for 10 minutes. A lot of times the computer will reset and function normal. At least you can most likely get it to unlock to get your clothes off.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
223 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
