Question about Olympus Camedia E-20N Digital Camera
Tripod socket What are the two holes in front and behind the tripod socket used for?
    Master:
  • 852 Answers
These holes are used for mounting the Support Arm for the TCON-300 Tele Extension Lens. The Support Arm has two pins that align to the holes at the camera's base.
Posted on Aug 31, 2005
SOURCE:
Fujifilm s5000 battery door broken
g'day
i broke mine a couple of years ago and fixed it by drilling and tapping two holes to suit 6-32 x 11/4" bolts as shown in the attached photo... one of the holes had to be enlarged to suit 6mm x20 because the thread is in a very flimsy area and had stripped
BTW the battery cover doesnt have to be removed from the camera as is shown in the photo! the photo was taken after i disassembled the camera for another repair
it works well with a couple of provisos...
1- the bolt heads may get in the way of mounting the camera on some tripods without modification
2-not as quick to change the batteries
3- dont screw the bolts down too tight - or the threads will strip
before this method i made a metal plate, the same shape as the base of the camera and used the camera tripod socket to attach it... thus keeping the battery door closed [ the advantage of this was that i could drill and tap a thread to attach the lot to a tripod - and the tripod mounting hole could be ia the centreline of the lens - making panoramas easier]11_28_2011_10_48_37_am.jpg
Nov 22, 2011 | Fuji FinePix S5000 Digital Camera
DONT KNOW HOW CAMERA GOES ON TRIPOD WILL ANY CAMERA WORK ON IT OR DOES JUST CERTAIN ONES WORK ON IT IT IS A DYNEX 60 " DIGITAL TRIPOD
It is usually obvious where the camera goes, so I am pretty sure that what you have is a tripod with a quick release plate that doesn't have the quick release plate fitted. This is very common when you buy a tripod second-hand. The quick release plates get attached to a camera and people forget to reunite them with the tripod before disposing of it.
If you bought the tripod new, then look in the packaging for a plate with a screw to attach to the normal camera tripod screw in socket. There ought to be more than one. The screw is standard throughout the world, except maybe Germany that used to use a different size. Any camera you have will have this socket on the bottom, a threaded hole about a quarter inch (5 or 6mm) in diameter. The plate will be a design peculiar to this make of tripod, and if you lose it or don't have it you will be unlikely to get another.
Jan 25, 2011 | Dynex 60" Universal Tripod
Cannot find where to plug a usb cable in!
The socket for the USB cable on this camera on the bottom of the camers in front of the tripod socket (that's the little round hole with a thread in it on the bottom of the camera)
Hope that helps
Jul 27, 2010 | Samsung Digimax L730 Digital Camera
How do I attach the camera to the tripod?
Check the back of the camera to check if there is a hole with thread.
The top part of the tripod usually comes out. Screw the top part of the tripod to the camera and after that attach it back to the tripod.
If you need further assistance, just leave a comment. Cheers
May 02, 2010 | Sunpak 8001UT Tripod
How do you mount an ext 90 telescope (meade) to its tripod (ext field tripod). both are unused out of the box
There are two holes in the base of the telescope that match up with the two thumb screws on the tripod. It's easier if you lift up the base of the tripod a little using the latitude scale shaft.
Read the manual front to back before you use the scope.
Nov 19, 2009 | Meade Optics
I need a replacement tripod socket for minolta stsi
Hi there and welcome to FixYa.
Depending of your use of the tripod, (meaning, if your a professional photographer, or just a hobbiest = how much money your willing to invest to fix it!) there are a couple things you can do.
Purchase a clamp on head for your tripod. There are many on the web to choose from.
Or: (if you want to truly McGuyver it)
Take off the the screw so the tripod head is flat then use double stick velcro tape. Put one half on the bottom of your camera and the other on the flat part of the tripod. That will do the job for the hobbiest with for very littel money.
Hope this helps.
Rob
Mar 24, 2009 | Minolta Maxxum STsi QD 35mm SLR Camera
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Mar 17, 2009 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
How to fit canon s5is on a tripod stand (fotomate)?
I'm not sure what you're asking. There is a threaded tripod socket on the bottom of the camera. You just screw the tripod into this socket. Is that what you were asking?
Nov 07, 2008 | Canon PowerShot S5 IS Digital Camera
Attaching camera to tripod
you need to find the "quick release plate" for that tripod
Nov 18, 2007 | Vivitar VPT-360 PROFESSIONAL FLUID-ACTION...
Olympus Camedia E-20N Digital Camera Logo
32 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
