Question about Pantone ColorVision Spyder2PRO Studio (GSX112) for PC
Device not recognized
When I plug in my Spyder2pro my computer tells me: device is not recognized. Ichecked the system (hardware) it says: unknown device. Tried everything, even my computershop can't find a solution. I did download the latest software, 2.3.5, doesn't help. Maybe it is conflicting with some program e.g. Photoshop CS3 I recently installed. Who can help me?
    Novelist:
  • 121 Answers
Stef holland,
If you were using CS2 and had calibrated your monitor with the Spyder 2pro your color profile should be the same and can be used in CS3. Match all of your color preference settings in CS3 to what you have them set for in CS2 you should be fine. Eventually you will want to upgrade the the Spyder3 pro or Elite which works in CS3 & 4. I don't think the Spyder went bad I'm pretty sure it doesn't work with the newer versions. Yes you'll have to uninstall Photoshop first check, to see if the device works with your older version of PS then calibrate the monitor again. Transfer your setting to the new PS after reinstalling it.
randy320sgi
Posted on Jan 07, 2009
Earthlink IBM PC camera won't turn on
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 20, 2012 | IBM Webcam
I upgrade my operating system from windows7 starter edition to windows7 ultimate, then when everything is done i check out some unknown devices "Other devices(!)" from the device manager and the...
Try to do a Windows 'Add Hardware" operation to get Win7 Plug-n-play to "recognize" the modem.
Under WinXp, it would be:
START > Control Panel > Add Hardware
Under Win7, it may (or may not) be similar).
Apr 18, 2011 | Computers & Internet
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore drivers...select usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
I install the driver, the computer recognized the veo camara and I try to use it but let me. The computer says the veo camara isn't plugged! :( Please Help!!!!!!!!!!!!!!
Feb 18, 2009 | Veo Stingray
My Computer and iTunes does not recognize my iPod
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Nov 24, 2008 | Apple iPod nano
I plugged my Memorex TravelDrive into my computer. It has always worked perfectly. This time I got the message that the USB device was not recognized and I can't get into my files.
THE FOLLOWING IS COURTESY OF MICROSOFT Help and Support
When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
Unrecognized device has been found.
This issue occurs because, when the computer comes out of S3 or S4, there is a five- to ten-second period when the selective suspend feature of the USB driver will interfere with detection of a new USB device connection. The time period depends on several factors. This includes the following factors:• Host controller hardware
• Attached hubs
• Attached devices
• USB driver versions
• Support for USB 2.0
• Additional system hardware or configurations that may change the timing
There may be other reasons that a USB device is not detected
Method 1
loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2
After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 3
Use the Device Manager to scan for new hardware. Follow these steps: 1. Click Start, click Run, type Devmgmt.msc, and then click OK..
2. On the Action menu, click Scan for hardware changes. This causes Windows to recognize new devices.
3. Close Device Manager and Control Panel.
Method 4
Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK.
2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties.
b. Click the Power Management tab.
c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
SIMILAR PROBLEMS AND SOLUTIONS loadTOCNode(1, 'moreinformation'); For more information about advanced troubleshooting tips for general USB problems, click the following article number to view the article in the Microsoft Knowledge Base: 310575 (http://support.microsoft.com/kb/310575/) Advanced troubleshooting tips for general USB problems in Windows XP For more information about how to troubleshoot unknown devices in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 314464 (http://support.microsoft.com/kb/314464/) How to troubleshoot unknown devices that are listed in Device Manager in Windows XP
Try restarting the computer with the device in. Sometimes if you clear the memory that might help (stating the machine without memory then put it back and start it again).
Jul 01, 2008 | Computers & Internet
Usb device not recognize
Try going into your control panel I JUST DID THIS!!!! because i had the same exact problem and it was killing me. Select your systems folder and click hardware you will see driver singing button click it and select "ignore install the software anyways" and that is it. it worked immediately after that simple change.
Apr 28, 2008 | Cameras
QuickCam Communicate STX Problems
uninstall the software
plug in your webcam
in the system tray you will see a icon indicating new hardware detected,then install the software..
if your computer is not recognizing the device plug into the other USB ports ,stil not detected there is a problem with your webcam
Dec 10, 2007 | Logitech QuickCam Communicate STX Personal...
My device is no loner recognized
Go into the device manager, click on View > Show hidden devices. Look under unknown devices or under USB for unknown devices. Also check under the section relating to the type of usb device. If you find an Unknown Device, or a device with an exclamation point, right click on it and uninstall. Disconnect the device, reboot and install the drivers/software for it if any. If it's still not working check it in another computer. If you cannot get it to work in either machine, the usb plug of the device is probably damaged. Possibly a loose solder joint. Have the manufacturer send you a new one if its still under warranty.
Aug 25, 2007 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Pantone ColorVision Spyder2PRO Studio (GSX112) for PC Logo
278 people viewed this question
Top Pantone Computers & Internet Experts
David Payne
David Payne
Are you a Pantone Computer and Internet Expert? Answer questions, earn points and help others
