Question about GE Kitchen Ranges
Oven temperature dropped during baking oven was on a couple hours before cooled down
  • 639 Answers
Hi, I'm Neil
It is a fire hazard! Be Careful!
Sounds like the thermostat is bad!
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Electric oven will not maintain temperature. drops 20 degrees
Jump online & get the schematics for your oven.. You'll need to troubleshoot the bake circuit, which is comprised of 2 - 120VAC legs (240VAC is applied during bake). One 120VAC leg is from the DLB relay and the other is from the Bake relay. if either one is bad, or not energizing, you won't get any power to the bake element. (The bake element runs 100% of the time during the bake cycle. broiler only operates 25% of the time during bake) I have had luck re-soldering the relay leg nodes on the backside of the relay board, as they develop "opens" over time. The relays are designed for ridiculous ##s of cycles, so they're not *usually* bad.
Dec 23, 2009 | Amana AOCS3040 Electric Single Oven
I have a GE JTP18 Trutemp. It seems to be taking
sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Jul 19, 2009 | GE Profile JTP18 Electric Single Oven
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
F2 appeared on the screen during self-cleaning
F2-During BAKE
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
F2-During CLEAN
Control senses oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Apr 16, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Why does the oven cool down during cooking. This
seems like the thermostat needs replacing, also make sure any programming mode, mechanical or digital is off
Mar 05, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
