Question about E-Mu 0404 Sound Card
All led's light up in my mixing desk
There is no output when I connect to the red (left) conection which is also connected to the mixing desk. When connected to the white (right) the lights just light up normally but I cannot record my voice.
I moved the sound card to another slot in the PC and it seems to have worked although I cannot get my vocals to record if you can help I would be grateful.
Alan
Posted on Aug 24, 2008
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
How to conect my wiring tv cabale to my stereo component
For a simple stereo connection If you have a spare set of inputs (CD, AUX, video but NOT Phono/LP) on your receiver, preamp or whatever makes your speakers make noise that accept a pair of red/white RCA type inputs connect the OUTPUT of either your cable box, satellite receiver or TV audio Left & Right (red & white RCA jacks) to the INPUT of your receiver. If your cable or satellite receiver has a digital OUTPUT (either optical or coaxial) and your receiver has a like INPUT and 5.1 surround sound capability you can connect that to give you a surround sound mix.
Feb 12, 2013 | Televison & Video
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
I am new . I don't no where to conect mix to
For the whole mix, there are two XLR (mic cable) sockets on the back panel labeled 'Main Output' Left and Right, if your amp has XLR inputs you should use these. Otherwise there are two jack sockets labeled 'Main Out'.
This is a complex desk with a lot of useful options, you're going to have to spend some time reading the manual. Have fun.
Jun 12, 2011 | Behringer XENYX 2442FX Mixer
I installed a 1987 monte carlo steering column in my 30 ford hot rod i need the color code of the wires so i can conect the directional signails up
H).l-blu wire connect to left front turn signal J).dk-blu wire connect to right front turn signals K).brown wire connect to hazard/flasher relay output L).purple wire conect to turn/flasher signal M). yellow wire connect to left rear stop hazard light N). dk-green wire connect to right rear stop/hazard light P) white wire connect to stop light swirch output
Jun 25, 2010 | Cars & Trucks
Using the red whit and yellow VCR cables, how do i
You must have a monaural (mono) TV even though it looks like you have speakers on each side. The VCR has stereo audio output red=right white=left yellow=video. Ideally you would buy a mixing tee to add the left and right signal. Or if your VCR supports it you can set it to mono output. Otherwise, just use the white (left) cable to feed the mono input (white) and of course the yellow to yellow for video. Just ignore the red wire or lightly tape over it to avoid any short. Best,
-Ken
Apr 16, 2010 | Apex Digital AT2402 24" TV
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a hq-31 mono 31 band eq with feedback
first connect your sound source(dvd player-vcr-...)to eq-input-------eq output--------line in in mixing desk.
Oct 13, 2009 | Audio Players & Recorders
I get two green power lights
checking conection inside you PC, check if all cables are connected respectivley prior to HARD drive must be connected and powered up
Oct 06, 2009 | HP Compaq Evo W6000 PC Desktop
Turning of oil service light on OBD II
My recommendation is definitely in the certified sevis because if you make a wrong conection wires can spoil the main computer
Jun 25, 2008 | 1996 BMW 318
E-Mu 0404 Sound Card Logo
129 people viewed this question
Top E-Mu Computers & Internet Experts
David
David
Willem.
Willem.
Steve
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
