Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Will not drain after the wash cycle, will not enter the rinse cycle
My washer stops after the wash cycle will not drain, if I advance the cycle knob manually the machine does not respond. Please help washer stops after cycle it does not drain or spin. stop and start same thing.
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
Posted on Aug 31, 2008
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    Washer will not advance in the rinse cycle,water just runs continuely.
    check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
    May 21, 2009 | Washing Machines
    Frigidaire top load washer won't rinse
    this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
    Mar 13, 2009 | Washing Machines
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    275 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
