Question about Dell Wireless 2350 Router
Cannot connect to internet via Actiontec M1000 (Qwest)
Any ideas what setting is causing me not to connect?
    President:
  • 2,961 Answers
Open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router, other than that you need to check the routers settings, like the password /username for your ISP connection and assuming you originally set it up using an RJ45 lan cable (supplied) before using the wireless.
Posted on Aug 23, 2008
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
What routers will not work with Kodak 5250 ?
This printer should work with any router. As long as you know the security on the router it can get connected, and that the router is functional.
Apr 08, 2010 | Kodak ESP 5 Printer
Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Feb 26, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
I have an actiontec m1000 router/modem that has only one ethernet port. I have a desktop connected to it, and wish to use a laptop as well. If I get the wireless attachment for the actiontec router/modem,...
Yes.
If this attachment occupies the router's Ethernet socket, then the solution would be to purchase a wireless USB adapter for your desktop, so that both can connect via WLAN, with the added benefit of less cables and more placement freedom :)
Be sure to configure WPA or WPA2 security on your WLAN network, WEP is very insecure and will welcome unwanted guests.
Nov 21, 2009 | Office Equipment & Supplies
Got Qwest DSL internet and now PS3 can't connect to internet. "Access Point Was Not Detected" What do I do? Modem is Actiontec PK5000. Wireless internet works fine.
I found out that the ps3 is case senitive for the password so it there is caps in the password use caps..the qwest guy gave me a password like fff3093fhfhjh3r and I had to use FFF3093FHFH blah blah
Oct 26, 2009 | Actiontec Computers & Internet
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless conection problems
As far as I can tell you can only connect to other people's computers via the network router in a wireless application. Even then your brothers computer must be on "share" setting to allow you to do so. Check your airport is working in the network settings function in preferences, if yes, go into you computer on the side bar there will be an icon called "network" click that once and you will see what your airport card is connected to and if your brothers cpu is on that network.
May 14, 2008 | Apple iMac 24" Desktop
Dell Wireless 2350 Router Logo
518 people viewed this question
Alun Cox
