Question about Nintendo Wii Console
Complete power failure
The machine just switched off all on its own after playing for about 10 minutes and now just not switch back on again - any help - or is it dead??
    Sergeant:
    Champion:
  • 250 Answers
It probably overheated. Make sure the wii is in it's silver base and that its on a flat solid surface away from other electronics so it gets plenty of air. Never sit it on the floor. To reset the ac adapter unplug it from the wall AND the wii. Let the adapter sit for 5 minutes and then plug it back in.
Posted on Sep 13, 2008
I have a 4 year old Bosch Ecologixx 7 self cleaning condenser dryer, WTW86561GB/02. The problem is after 10 minutes the machine just switches off, and the display panel goes dark
sounds like the thermal safety overload is cutting the power due to overheating hence why it just turns back on after a certain time, when the safety overload reaches a certain temperature it will cut the power to the machine or in some cases just the heating elements, once it cools down it resets and power is restored and by using the warm setting it obviously isn't as hot so its not overheating, its highly likely it is all blocked up internally with lint (i know it says self cleaning but they never work for more than a few years before requiring a proper clean and service)
Jan 30, 2017 | Bosch Washing Machines
Como soluciono error c-9401
the bright light under the big glass failure to turn on, raise the doc feeder then hit the start button to copy something a very bight light should come on, if not get the exposure lamp and or board replaced
try this once if the code comes back do above
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
Feb 14, 2014 | Konica Minolta bizhub C351 All-In-One...
Hello, I have a T790 with 60.2:17 error since the
Process 1..
1. Switch the power off from the back of the product, wait two minutes, then switch it back on again.
2. Check the power cord; try connecting it to another power socket.
3. Check that the product is properly connected in all other respects.
4. Switch the power off from the back of the product; remove the Formatter; reinsert the Formatter; switch the power on again.
Process 2..
1. Turn off the product with the Power Key on the left of the Touch Control Panel.
2. Press and release the Power Key to turn on the product.
3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel come on and then press
and release one after another the RIGHT -> HOME buttons.
4. Wait for the unit to complete the booting process. The logs are now enabled in the product even if
the product hangs and shows a system error.
Once U got the error, check the error related spare, replace it, any help post your query..
Formatter snap:
Aug 22, 2013 | HEWLETT-PACKARD T790 InkJet Plotter...
Getting error code C11A4 can you help me fix this please?
Some basic reset procedures.
A. Open and close the front door.
B. Power off the machine, wait 30 seconds power on.
C. Power down the machine, unplug from the wall for 1 minute, plug in and power on.
D. 13.1 Trouble resetting
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than 10 seconds after.
Nov 19, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Have a Panasonic kx-e700m typewriter. I came back from vacation and the display reads "Machine is busy." I have tried to clear it by turning off the machine, typing "code+K" and have not been successf
hello sonya, this may or may not work, but leave power switch on, open your top cover, unplug machine and let sit for about 10-15 minutes. plug back in, close cover and see if you can type. if it still doesn't work, you're most likely looking at a "hard" failure that can only be repaired by a tech.
hth and good luck,
razors
Apr 13, 2009 | Office Equipment & Supplies
Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Apr 18, 2008 | Samsung Syncmaster 192N 19" LCD Monitor
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
