Question about Car Audio & Video
Xtant power amplifier
I just got a xtant technologies 3150c amplifier, he says he fried it but hes not very bright so i was wondering if u could tell me how it works and if i can look 2 see if i can find te problem, when he had it also if it helps solve the problem he had it on mono for his one 10inch.
  • 631 Answers
Did you try hooking the amp up to see if it works?
Use a relatively small fuse (no larger than 15 amps) in case there is a serious problem. The small fuse will help protect the amplifier.
The following page will help you with basic repair. Read through it to familiarize yourself with basic amplifier components.
Basic Car Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Aug 23, 2008
XTANT AMPLIFIER GETS UNUSUALLY HOT WITH MINIMAL LOAD.
Check your ground wire. If its loose or bad. It will cause your amp to run hot, and can damage it
Nov 10, 2011 | Car Audio & Video
I am looking to buy a replacement Xtant RGM.
m you nead to chak with the factory of those types of amplifiers of look in a shop
Nov 16, 2010 | Xtant RGM Module Amplifier Accessory -...
Are xtant 604x sub amp
yes that is a badass amp do u wanna sell it
Feb 26, 2010 | Xtant X604 Car Audio Amplifier
Boss RT 1045 not powering up
HES PROBABLY TALKIN ABOUT A CAPICITOR CAP IT ACTS A POWER SUPPLY A SECOND BATTERY IF U WILL IT HELPS TO NOT DRAIN UR POWER FROM UR MAIN BATT.
Feb 10, 2010 | Boss RT-1045 Car Audio Amplifier
The overcurrent protection light keeps coming on; i am using the proper guage wiring and the correct fuse size i have adjusted the subwoofer control down on the deck and also the amp itself, the deck is...
How long has it been since you cleaned it with dust off? Xtant say's once a month. Dust can create a big buildup of static on the boards and anything is possible. Hope this helps
Jul 18, 2009 | Xtant A3001 Car Audio Amplifier
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Xtant 3300x
It sounds like it's going into protection mode.
Do any of the channels pop when it's switching on and off?
If you power it up via a single 15 amp fuse (in series with the B+ line), does it blow the fuse when it powers up?
Sep 16, 2008 | Car Audio & Video
Xtant 3300X schematics
Xtant never released the schematics for their amps.
What sort of problem are you having with yours?
Sep 14, 2008 | Car Audio & Video
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
