Question about Ericsson Lands Phones
My battery is completely flat and how do i charge it with a usb charger?
  • 79 Answers
Are you using a mobile phone battery charger with USB interface and USB data cables designed for cell phones?
Posted on Aug 23, 2008
Tablet will not charge
Assuming that you charger is not defective, and that you have no other electrical issues, then if your battery has been allowed to completely flat line, it may no longer accept a charge from the normal wall charger. Then you can try to trickle charge your tablet from a low voltage/current source, such as a USB port or a low power phone charger (5v/500ma). Try a trickle charge for 8 - 24 hours on your tablet. After that try your normal charger and see if it will now charge properly.
If that does not work, and you have previously ruled out your charger, then I would suggest contacting the manufacturer, as it is likely some other fault, either with the battery, or the tablet itself.
I post on behalf of HP.
Jul 31, 2015 | Tablets & eReaders
How do I know its fully charged?
It depends if the charger are intelligent or not, check the owners manual.sometimes changes, it depends the manufacturer charger.when it compares charges, disconect itself the circuit. not always.
Oct 18, 2014 | SoundLogic Sound Logic Power Cell...
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
FLAT BATTERY - WHAT SHOULD I SET MY NEW CHARGER ON TO CHARGE A FLAT BATTERY ON A VICTORY JACKPOT VEGAS 2010
2 amps. If the battery is completely dead, and will not charge, try connecting it to a known good battery with jumper cables and then connect the charger.
Apr 11, 2013 | 2008 Victory Vegas Jackpot
During a game the psp turnrd off. i put charger in to psp and it still wont turn on. do i need a new battery? can they go off that quick?
does the light go on when on charger? if so its just a completely flat battery. you might not need a new one, charge it for half before you try to switch it on again
Nov 24, 2010 | Sony PlayStation Portable (PSP) Console
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ipod ''dead''
Plug your iPod into a wall charger, let it lie for a couple of hours. When these batteries become completely flat, it won't easily charge through computer usb, so try the wall charger, see if it works.
Nov 17, 2009 | Apple iPod 4th Generation MP3 Player
Not wroking
Apparently if you let the battery go completely flat it won't charge via USB and you'll have to use a proper plug in mains charger.
I've just had the same problem with mine and I've been searching the house high and low for the charger!
Mar 19, 2008 | O2 XDA Mini S Smartphone
My a701
Hi Kane
When a battery gets really low, it may not take a charge straight away, leave it connected for several hours, it may come back. If not, a new battery is in order, and a charger I guess also:)
regards
Graeme
Mar 11, 2008 | Cell Phones
Lands Phones Logo
23 people viewed this question
Top Ericsson Lands Phones Experts
Ali Reza
Level 1 Expert
Are you an Ericsson Lands Phone Expert? Answer questions, earn points and help others
