Help looking for a diogram of a compaq pressario tower. i put a new power supplier in and don't know what hook ups go were
  • 3,051 Answers
The main thing that u need to know is to connect the power supply to the motherboard where the old one was and the cords with the dual 4 prong wires can be used for either a hard drive with a nother harddrive or 2 cd roms ok but dont cross them ie cd rom and harddrive the small square plug ins are for the a drive ok or zip drive please keep me informed how your progress is going i can help more if needed
best regards mike
Posted on Aug 26, 2008
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
Fujitsu tower smoke out of rear no power
Sounds like you need a new power supply. Have a look at the labels on the old one inside the tower. The thing to look for is the total power output in Watts.
If it's 300watts for example then buy another with the same or higher wattage, I would go for a higher one. Then check the leads that come out the back in to the drives and motherboard etc. Especially the power to the motherboard. If it's a 20 pin socket thats the standard, if it's a 24 pin socket thats the more modern type but can still be used on a 20 pin connector on the motherboard, you just don't use the other 4 pin plug thats usually seperate at the end of the plug. The power supply is usually only held in place with 4 screws on the outside of the tower.
The main power connector to the motherboard has a little clip on the side of the plug that you have to press in to remove, it's like a little hook to stop it comming loose. There may also be a black and yellow wire 4 pin plug near the pocessor heatsink on fan, that also has a clip to press.It's not a hard job, just take your time and don't apply to much pressure when connecting the new leads to the board.
Feb 05, 2012 | Fujitsu Computers & Internet
Blank screen
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 06, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
Found Compaq Pressario in Trash Today - is it worth getting fixed
Start with buying a universal charger from an electronics store.
See if it will turn on. If not, it may not be worth keeping.
Sell it on ebay for parts if thats the case.
Mar 10, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
