Question about Frigidaire ATF6000ES Front Load Washer
Error code E21
I have the error code that flashes E21. How do I handle this? I will have to do it myself so I hope it is not that difficult. We have 7 people that live here and 4 are kids. I am drowning in dirty clothes. Please help. Thanks, Regina
    New Friend:
  • 10 Answers
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to the Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try using compressed air into the drain hose at the rear of the washer. No disassembly required. It only took a minute to do from my compressor. I suppose it would be just as effective with a garden hose, but a little more messy. Anyway, 100% problem solved! No more error code, and as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained. No repair bill. I just hope that whatever was restricting the drain flow does not happen again.
Posted on Sep 29, 2013
  • Pete Conquest Sep 29, 2013
    I forgot to add, it only took a few seconds of applying the air into the drainhose to see the bubbles appear in the washer's tub. At that point I knew most any obstruction was gone.
  • 725 Answers
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
Posted on Aug 24, 2008
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
Error code e21: Bushes replaced by engineer but unable to reset machine. E21 still shows. Bosch totally unhelpful.
the electronics lock out during power surges like you would get from brush failure giving e 21 error. you have to access service test prog to reset this, and it is not in public domain.
i do know how to reset it though but difficult to explain on this forum you may find a you tube video if you search online.
Sep 24, 2016 | Bosch Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Canon DR5020 E21 error
Canon Scanners are reliable. Canon has chosen error codes logically, 'P' os Paper related, 'C' os cover related, 'E' is Engineering Support related.
E21 is Document Motor Trouble. E2 is Separation Motor Trouble. Check of connection and load or you may to replace motor. Try connecting the motor to a different location and if the error is same, probably there is no motor fault, if it changes then it definitely motor fault. As a last thing you may need to change the PCB on the side.
S. Mohan, Chennai, India
Jul 03, 2009 | Canon DR-5020 Path-Through Scanner
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
Jan 08, 2009 | Office Equipment & Supplies
Error code E21
you need a phillps screwdriver remove the top . control panel then the front... hope it helps
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
4,732 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
