Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Keeps clicking after lit
Keeps clicking after burner has lit (all 4) doesn't do it all the time
  • Anonymous Aug 28, 2008
    I have the exact problem with the clicking on all burners intermittently....sometimes none, sometimes all, sometimes one or another. The explanation that it isn't the igniter but the knob being stuck in the "ignite" possition makes sence and has to be the problem...can't believe we never thought of it being the knobs before. I tried it and the know that isn't popping back up after ignition is the culprit Only problem is that I am not sure how to fix this. There is a foam like "washer" underneath the knob that I think may be loosing elasticity with age. Problem is I was able to get one of the knobs off but my husband and I were unable to pry off the know that was currently causing the clicking. I suspect the foam as it wasn't dirty under the knobs as there is enough of a space to clean underneath with a rag without removal I need to figure out if there is a method for removing the knobs
  • tamitj Nov 06, 2008
    after turning on the burner, it keeps clicking
    President:
  • 2,961 Answers
Your ignition button is sticking down after you press it to light the burners, give it a few taps and clean underneath the button.
Posted on Aug 23, 2008
I have the same problem. It's not a gas grill it's Jen Air gas stove top. It automatically sparks when turn a burner on. There is no push button. Lady you just pull straight up on the knobs to remove them. I don't think thats the problem (rubber gasket under the knob) though.
Posted on Nov 06, 2008
heatman101
  • 43501 Answers
SOURCE: All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
Posted on Sep 30, 2010
SOURCE: Clicking noise on cooktop even when all burners ignite
Jsut a guess - see this solution: http://www.fixya.com/support/t119696-constant_clicking_when_turned
Posted on Mar 31, 2007
  • 222 Answers
SOURCE: one ignitor keeps clicking after burner is lit.
clean the bottom of the knob by using vaccium,remove the knob then clean it.return the knob in possition how u remove.
tnx gerbee
Posted on Jul 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: all 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: Stove-top burners
heatman101
bvn
Even after the burners are lit they keep on trying to ignite, sometimes all four will be clicking.
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 31, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
I have had my cooktop for 5 years The ignitor stays lit when cooking and I have had to replace the ignitor for the grill 4 times. Why is this happening?
You are getting too much water around the knobs...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
heatman101
Jan 12, 2011 | KitchenAid Architect KGCP484KSS Gas...
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Piezo goes off every 10 seconds.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
Same one - ignition click will not stop. Is there a solution?
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
All 4 igniters keep clicking, when one is on
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Gas burners lit, but electronic ignition still clicks
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Stove-top burners
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
655 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
