Question about Whirlpool Calypso GVW9959K Top Load Washer
I'm also having trouble with the Elite Calypso as it seems many mnay people are, what can we all do, Sears won't do a thing without charging top dollar
Kenmore Elite Washer with Calypso. We have one that is about 4 or 5 years old, we are the second owners of this home and washer was here. Yesterday it stopped mid cycle, and the clothes were soaked, so I cleared code which I did not notice and started it again, same thing happened with-in a minute but "Ld" code came up then I moved the drain hose around and it made it through the complete cycle. Today it isn't working again only and error code "SL" came on so I did what manual said and it worked for a minute then the error code "ob" came on so I opened the lid shuffled the clothes around and it was a very small load that this should not have happened; it made it through the rest of the cycle. I then tried to run an empty load to see what happens but cannot because "ob" keeps coming on and stopping the machine even with nothing in it.
  • Anonymous Sep 03, 2008
    ld keeps popping up wont drain.
  • jbohringer1 Sep 04, 2008
    same thing. I think the whole calypso leveling system is wore out. I took it apart and it don't look good. 6 years old.
After discovering the high cost professional repair, I accessed this website to determine whether the problem might be a quick fix. Thank you very much for your expert advice! Thanks to you, I saved hundreds of dollars.
Symptoms: Cycle halts with little/no draining, followed by error displays, especially "ob" and "ld". Occasional leakage of several cups of water.
Problem: Several underwires from various females' undergarmets had become lodged in the last drain compartment, just before water exits to the drain hose.
Solution: Once the clog/wires were removed, the machine functioned normally.
Process: First disconnect power and water supplies to the unit. Next, determine if someting is stuck in the drain hose or in the compartment that empties into it by removing the back panel. In my case, I could see wires and clogs of lint through the translucent yellow plastic of the bottom compartment.
To acces the clog, I drained most of the water by lowering the end of the drain hose as much as possible before disconnecting it, then sucked the rest up with a wet/dry vac when I removed the hose. Then I was able to pull the wires out through the drain holes (it was necessary to disconnect the other three hoses from that compartment) using a coat hanger bent and twisted appropriately.
Total time for a "handy" amateur that had never worked on a major appliance before: 1-2 hours. $ saved on a repair housecall: $200-300
Posted on Feb 11, 2009
I'll bet the drain pump is slipping. See my post above. I was able to do a temporary fix by gluing the pump motor shaft in the pump rotor. It is still working 100%.
Posted on Aug 28, 2008
I have an Kenmore Elite Calypso Model #110.21086000. It want go into the rinse, spin cycle. I figure I need either the Microcomputer or Electronic Control board. How can I know which one to get?
your trying to fix it on the cheap,,,,bad idear,,,if you get the wrong part will you be able to swop it?
answer is,,,no! ,,,,find out how much it cost for a call out charge to fix it,,,
Nov 28, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I need to find a downloadable user manual for Kenmore Elite Calypso washer
See the following Sears site for PDF manuals.
http://www.managemylife.com/mmh/owner_manuals/search?query=elite+calypso
Sep 30, 2010 | Washing Machines
Kenmore elite calypso wash motion top loader won t come on at all after power outage. checked breaker and outlet.
Unplug the unit and let it sit unplugged for 30 minutes. There is a power filter on the AC input line and sometimes power surges can cause it to need to bleed off the voltage from capacitors. There is a test procedure to see if the filter needs to be replaced but so far every time this has happened to our Calpyso, we pull the plug for a bit and the washer recovers.
There isn't enough space on this text box to post the removal & replacement procedure for the line filter, but you can find it at www.pcappliancerepair.com and look up the part # on the Sears Parts Direct site for your model # specifically.
Sep 20, 2009 | Kenmore Elite 21086
I did an online Chat with Sears today. (no
Honestly, on that machine, I don't have a clue where your clothes could go. It couldn't get under the aggitator plate unless it was so loose it was about to fly out. It doesn't do a flood rinse to send them over the top. And the pump in those units would stop up on anything. So they are not going down the drain. Besides the check balls would stop them.
jim
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer no pwer
If the dryer does nothing at all, it's probably the door switch. Give it a good look over.You Does the light com on inside when you open the door? Does it appear to have power but just won't start?
Jul 24, 2009 | Dryers
Is there a solution to fix the control panel without having to call repair man??? Kenmore Elite Oasis HE top load Tks, Lisa
Unless you can take the panel apart and your good with wiring and electric - call a seviceman. You did not say what the trouble was with the panel is it the timer or water leveler or the on button ( Control of what?), Sears has a contract you can purchase and that will cover everything ( age of the machine will matter) any thing over 5 yrs - a contract is not worth it to them or you. Mostly them!!
Jul 18, 2009 | Washing Machines
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
312 people viewed this question
Dan Webster
Dan Webster
Sal De
